Vibration in 4 link at 60 mph - Team Camaro Tech
post #1 of 31 (permalink) Old Sep 13th, 09, 04:25 AM Thread Starter
Dave C
I have a vibration in the back of the car at 60 when I decelerate it seems to get better when it warms up.I had it up on the lift and the diagonal link pivots or should I say twists very easy on the heigm ends.The drive shaft feals tight when I tug on it.The play in the right tire when I roll it back and forth seems to be more than the left.I ballenced the tires about a month ago and it seemed to get better not to much though it happened when I reached 80 mph.If anyone has any ideas or suggestions I would appreciate it....Thanks in addvance.....
PRO.ST69orange
post #2 of 31 (permalink) Old Sep 13th, 09, 05:21 AM
Re: Vibration in 4 link at 60 mph
Is your drive shaft angle good, i dont know what degree it is supposed to be but it should angle down a bit.
ledoux67 is offline
post #3 of 31 (permalink) Old Sep 13th, 09, 07:20 AM Thread Starter
Dave C
This is set at 2% from the drive shaft I set this previously.
PRO.ST69orange
post #4 of 31 (permalink) Old Sep 13th, 09, 08:04 AM
Skip
Skeeter55's Avatar
Dave are the rims centered on the studs, try taking all the lugs off and check the rim/studs for play (not centered). Also if yo have drums make sure the studs/holes in the drums are centered with the studs....
Ive had this problem with my 9" when i ordered new drums and axles. One more thing about the play in one wheel vrs the other, check the back lash. To much back lash will cause all sorts of problems.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 31 (permalink) Old Sep 13th, 09, 08:12 AM
Dave.....just a guess...the balancing weight on the driveshaft??????
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #6 of 31 (permalink) Old Sep 13th, 09, 10:26 AM Thread Starter
Dave C
Skip,I have wilwood and self centring lugs.
David,I painted the drive shaft when I got it back the weights are still on as I dont see and bare spots.
Do you think if I put it a a dyno I may be able to see something.This has got me pegged....
PRO.ST69orange
post #7 of 31 (permalink) Old Sep 13th, 09, 11:37 AM
Now I'm wondering if you have an axle bearing problem?????????
David F.
Turbo 400
post #8 of 31 (permalink) Old Sep 13th, 09, 11:46 AM
Skip
Skeeter55's Avatar
David F.
X2 or to much back lash, needs to be re-shimmed.
post #9 of 31 (permalink) Old Sep 13th, 09, 02:59 PM
george
Inner pinion race and bearing rough..typically has a growl with a vibration tho on decel.Hard to say at this point.just food for thought.Can you drop the diff fluid for inspection?
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #10 of 31 (permalink) Old Sep 13th, 09, 03:11 PM Thread Starter
Dave C
David F.
I did before I had one crack it madenoise at 2mph though.
PRO.ST69orange
post #11 of 31 (permalink) Old Sep 13th, 09, 03:14 PM Thread Starter
Dave C
My buddy and I just put new gears in it about 450 miles ago and the mesh was just about perfect.
PRO.ST69orange
post #12 of 31 (permalink) Old Sep 13th, 09, 04:47 PM
prostreet69camaro's Avatar
Dave,
I know you have had the car together a year or so. Has it done it from the start or did it just start doing it? Have you changed anything resently.
prostreet69camaro is offline
post #13 of 31 (permalink) Old Sep 14th, 09, 10:49 AM
Vibration on decel usually means driveshaft angle. Should it not be around 4.5 degrees? That's where I set my 4-link in my 69 and it's perfect.
69 SS396 Camaro, 4link, 12bolt posi, Speedtech LCA / UCA's, Hotchkis 2" drop front springs/sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
g356gear is offline
post #14 of 31 (permalink) Old Sep 14th, 09, 03:58 PM Thread Starter
Dave C
Originally Posted by prostreet69camaro View Post
Dave,
I am not sure...
PRO.ST69orange
post #15 of 31 (permalink) Old Sep 14th, 09, 03:59 PM Thread Starter
Dave C
I was under the impression it was 2 degrees....
PRO.ST69orange
