Gears - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 14th, 09, 06:37 PM Thread Starter
Jeff
Gears
My engine builder does'nt like the tall gears I have for my ride, he recommends 3.70's for cruisin. I have a set of 4.86's now. Engine is a 496 bbc w/a th400 tranny and 30x18.5 tires. What are all you big tire guys runnin for cruisin gears?
I may be old and slow, but ........what the heck was I gonna say?
tilley88 is offline
post #2 of 13 (permalink) Old Oct 14th, 09, 06:53 PM
prostreet69camaro's Avatar
Re: Gears
I had 513 with a 33" tall tire. I went to a 390 with a 33" tall tire and love it. Great for cruisin and a big block doesnt need all that gear. I had the 513 behind a 406 before.
prostreet69camaro is offline
post #3 of 13 (permalink) Old Oct 14th, 09, 06:59 PM
Re: Gears
3.90 with 33" tall tire, BBC & TH-400......same comment as Mike^^^^^^^^.....cruising is great!!!!
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #4 of 13 (permalink) Old Oct 14th, 09, 07:16 PM Thread Starter
Jeff
Re: Gears
Looks like 3.70's with the 30" tire is good. What knid of RPM are you guys turning at say, 60mph?
tilley88 is offline
post #5 of 13 (permalink) Old Oct 15th, 09, 06:50 AM
Re: Gears
About 2500 rpm...
post #6 of 13 (permalink) Old Oct 15th, 09, 12:10 PM
Matt
Blade's Avatar
Send a message via AIM to Blade
Re: Gears
I have 456s but the car doesn't run so I can help out with info!
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
1967 Prostreet Camaro
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Blade is offline
post #7 of 13 (permalink) Old Oct 15th, 09, 04:41 PM
Re: Gears
Originally Posted by prostreet69camaro View Post
About 2500 rpm...
Very close to me as well.......about 2600 rpm for me.
David F.
Turbo 400
post #8 of 13 (permalink) Old Oct 15th, 09, 09:23 PM
Royce
Re: Gears
3.70's should put you where you want to be. I have a 30" tall tire on my Nova and went with 3.50's. 3.70'sshould put you right about 2500RPM @ 65mph.
You can play around here: http://www.richmondgear.com/streetcalculators.html and plug in different gear ratios/cruise speeds and figure out where you want to be
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #9 of 13 (permalink) Old Oct 16th, 09, 03:34 AM Thread Starter
Jeff
Re: Gears
Thanks for the help. I'm going with 3.70's for sure.
tilley88 is offline
post #10 of 13 (permalink) Old Oct 16th, 09, 05:26 AM
Jerry
Re: Gears
Jeff, maybe this will help. I "borrowed" it from another forum.
http://www.carforums.net/rearcalc.php
good luck
Jerry
67 RS coupe, Black
68 Pro street Torch Red, blown 427
rat3j396 is offline
post #11 of 13 (permalink) Old Oct 17th, 09, 08:02 AM
George
Re: Gears
Again just depends alllll on how your going to use the car!
with your 30" tall tire ummm lets say your going to do double duty mostly street some strip 4.11- 3.90 will work great.
Im running 33x19.5's leaning towards a 4.56 but im running a 406 that bb will pick up a fairly decent gear in the 3.70-3.90 range easy and you'll like it better than the steep ones you have now. and so will your engine!
1948 Chevrolet Fleetline Areosedan PRO STREET!
406 Solid Roller motor!
PRO 48 Fleetline is offline
post #12 of 13 (permalink) Old Oct 19th, 09, 08:11 AM Thread Starter
Jeff
Re: Gears
Thanks, 3.70-3.90 it is!!!! Now, anybody got a clue on what rear springs I need?
tilley88 is offline
post #13 of 13 (permalink) Old Oct 19th, 09, 08:46 AM
Royce
Re: Gears
Depends on how much the car weighs. I would call a place like Chris Alston Chassisworks www.cachassisworks.com and see what they suggest.
