Body roll...help!!!!!!! - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 11th, 10, 10:44 AM Thread Starter
Eric
Ok I have the mini tub complete on my 69, problem is after moving each spring in about 6" on each side and moving the shocks inward to a straight up and down position, the car has developed serious body roll. What is your suggestions to fix this? Pictures are always helpful.
Eric Bowling
2008 Ohio Crankshaft No Box Nationals Winner
1969 Camaro
406 sbc
Edelbrock Performer RPM Aluminum Heads
400 turbo
5600 8 inch Coan Converter
Transbrake
4.56 12 bolt
750 Holley RaceonE85.com Carb
ericsz is offline
post #2 of 13 (permalink) Old Mar 11th, 10, 11:33 AM
Ron
Re: Body roll...help!!!!!!!
A Sway Bar (NOT the Link Type) will help, but probably have to Customize one from a Smaller Car to fit the spacing.
Here's a PIC of the F41 Option on my 70Z:
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 13 (permalink) Old Mar 11th, 10, 01:40 PM
Fred
Here's my Addco.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 13 (permalink) Old Mar 11th, 10, 03:34 PM
Yes you are right Your picts would help.
john68 is offline
post #5 of 13 (permalink) Old Mar 12th, 10, 07:09 AM
Steven
Now that your springs and shocks are further inward, they have less leverage to resist body roll. Depending on how good your shocks are now, you may need a stiffer set...or get stiffer leafs too. I think that adding a sway bar at this point may mask the crux of the problem that you now have.
sik68 is offline
post #6 of 13 (permalink) Old Mar 12th, 10, 08:11 AM Thread Starter
Eric
I have the ranchos out back, and just to note in case you didn't realize this is a Drag Race Application. I tightened the shocks up a bit and it seemed to help quite a bit, I will be testing in a couple weeks to see what it does on the track and I will go from there, I just wanted to see what some of you guys have done to limit the body roll..
Eric Bowling
1969 Camaro
406 sbc
400 turbo
Transbrake
4.56 12 bolt
ericsz is offline
post #7 of 13 (permalink) Old Mar 12th, 10, 08:17 AM
Eric
You need an ARB or anti roll bar,Dont put stiffer springs in it till you talk to TRZmotorsports 407-933-7385.Call them,nice regular guys with a ton of great products and experience with cars like yours.They will help you!
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
post #8 of 13 (permalink) Old Mar 12th, 10, 12:16 PM
Fred
Calling Addco is a very good thing too. But yeah, drag racing is not their forte'.
128.79mph 1.428 60'
post #9 of 13 (permalink) Old Mar 12th, 10, 02:15 PM
Ron
By Tunneling you end up with a TOY not a RIDE, BIG Difference ;o)
Z15CAM is offline
post #10 of 13 (permalink) Old Mar 12th, 10, 03:05 PM
Little steep on price but you might find cheaper ???
http://www.summitracing.com/parts/CEE-2020/?rtype=10
68 Camaro~LSx ~all motor
post #11 of 13 (permalink) Old Mar 12th, 10, 03:07 PM
Check with Alston, or other good, they all make a great weld in rear bar,
john68 is offline
post #12 of 13 (permalink) Old Apr 7th, 10, 12:32 PM Thread Starter
Eric
Took the car out his weekend and Blew the Drive Shaft out of it, could body roll do this? The thing dead hooked the first pass BUT the body twisted BAD!, I figure its either a pinion angle issue or the body roll caused it, whats your thoughts? I am looking for a low budget cheap way to fix the body roll, I would love to see some pics of some anti roll bars installed in the back of some 1st gens with leaf springs still in if anyone has them please please post them as I have no idea how to install one. Thanks!
Eric Bowling
1969 Camaro
406 sbc
400 turbo
Transbrake
4.56 12 bolt
ericsz is offline
post #13 of 13 (permalink) Old Apr 8th, 10, 06:43 AM Thread Starter
Eric
Think if I put shocks on the outside of each side it would help? THinking about being the only car to run 4 shocks out back.
Eric Bowling
1969 Camaro
406 sbc
400 turbo
Transbrake
4.56 12 bolt
ericsz is offline
