pro street wheel tubs - Team Camaro Tech
post #1 of 17 (permalink) Old Mar 23rd, 10, 01:24 PM Thread Starter
jack
im building a pro touring 67 firebird but a while back i was givin a set of aluminum pro street wheel tubs when i bought a cage and frame rails. since i needed to tub the wheels anyways i took them and its almost time to start getting them in. im also replacing the rear quarter skins so if there is a prefered order, please let me know. how do you guys handle the issue of the trunk hinge support? any install pictures? thanks
freeskier is offline
post #2 of 17 (permalink) Old Mar 24th, 10, 04:07 AM
Dave C
Re: pro street wheel tubs
Wrong section you will be better over at PT.I think you will be better with a set of mini tubs from DSE...JMO...For the question of trunt hinge supports it is better to use steel tubbs....
PRO.ST69orange
post #3 of 17 (permalink) Old Mar 24th, 10, 09:29 AM Thread Starter
jack
i would also rather use the DSE mini tubs but this is what i have and there is no room in the budget for a change. im just looking for some pictures
post #4 of 17 (permalink) Old Mar 24th, 10, 04:52 PM
Jack,
The trunk hinge supports on my Camaro were trimmed on the bottom to compensate for the added height of the wheel tubs,then rewelded to the wheel tub. I don't have the best picture for illustration purposes but you can at least see the hinge support sitting on top of the wheel tub.
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #5 of 17 (permalink) Old Mar 24th, 10, 05:12 PM
Dave C
It is going to be hard to weld steel to aluminum actualy you cant do it.You will need to make some L brackets pop rivet them to the tubbs and weld to the brackets.I personaly like steel for the street because aluminum is very noisy.40" steel tubs are only about $80 I would recommend switching to steel at least.
PRO.ST69orange
post #6 of 17 (permalink) Old Mar 24th, 10, 05:18 PM
Excellent point Dave !!!! I forgot to mention that my tubs are steel .
David F.
www.firstgens.com
Turbo 400
post #7 of 17 (permalink) Old Mar 24th, 10, 09:11 PM Thread Starter
jack
ok thanks for the help, im not sure where im going to go. mini tubs are out as i need the whole wheel well but i dont need HUGE tubs so i have to look around
post #8 of 17 (permalink) Old Mar 25th, 10, 03:40 AM
Dave C
You can get 36" steel tubs and cut them what ever width you want and instal at any hight as well.They just aint gonna look as pretty.
PRO.ST69orange
post #9 of 17 (permalink) Old Mar 25th, 10, 12:23 PM Thread Starter
jack
ill trim it up with a nibbler and tuck it all away sumhow.
post #10 of 17 (permalink) Old Mar 25th, 10, 01:02 PM
prostreet69camaro's Avatar
Buy steel tubs. Running aluminum tubs on the street is real noisy and rocks put big dents in the aluminum. You can also put carpet over them which will help.
prostreet69camaro is offline
post #11 of 17 (permalink) Old Mar 25th, 10, 02:35 PM Thread Starter
jack
im going to put the aluminum ones up for sale this week and go from there. any idea whats the most narrow steel tub i can pick up in that price range?
post #12 of 17 (permalink) Old Mar 25th, 10, 02:46 PM
Steve69SS396's Avatar
Just trim them to fit. When I mini tubbed my car I used these 24" X 36" tubs from Alston.
http://www.cachassisworks.com/p-431-...ubs-24x36.aspx
Steve69SS396 is offline
post #13 of 17 (permalink) Old Mar 25th, 10, 04:44 PM Thread Starter
jack
and then just welded everything back togather?
post #14 of 17 (permalink) Old Mar 25th, 10, 04:53 PM
Dave C
The problem with tubs instead of mini tubs is they wont attach to the wheel lip where mini tubs will.I fibre glassed mine to the quarter if you weldthere is a chance of warping.
PRO.ST69orange
post #15 of 17 (permalink) Old Apr 1st, 10, 06:08 AM
67 455 Bird ragtop's Avatar
I'v'e already cut out my stock wells and had alum tubs made years ago whan I back halfed my car. Now that I'm finally starting to really put my car back together will DSE's mini tubes work or should I ditch the alum tubs and use them as a pattern for steel tubs ??
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
