strip or blast 9" center section??? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 1st, 10, 06:57 AM Thread Starter
67 455 Bird ragtop's Avatar
Probaly a stupid question but I thought I'd ask anyway. I need to strip the old paint off the center section of my 9" rear end. Since it's all assembled I assume the 100% only way to remove the old paint is to use paint striper. I doubt I should have it sand blasted.
Correct ???
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 6 (permalink) Old Apr 1st, 10, 07:15 AM
Re: strip or blast 9" center section???
Correct ???
Use the paint stripper. Don't risk getting blasting media in the gearset or carrier assembly.
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 6 (permalink) Old Apr 1st, 10, 07:20 AM Thread Starter
David F.
www.firstgens.com
Figured it was a no brainer ...
post #4 of 6 (permalink) Old Apr 1st, 10, 11:57 AM
prostreet69camaro's Avatar
I had my housing sand blasted years ago and it was a pain to get all the sand out. That gear oil really stuck to the sand and I had to use brake cleaner to finally get it all out.
prostreet69camaro is offline
post #5 of 6 (permalink) Old Apr 1st, 10, 12:23 PM Thread Starter
The main housing has been cleaned so I don't worry about having it blasted. I'll just use striper on the gear "chunk".
post #6 of 6 (permalink) Old Oct 4th, 10, 12:02 PM Thread Starter
What about soda blasting??
