what to use for floor? - Team Camaro Tech
post #1 of 18 (permalink) Old May 27th, 10, 09:46 AM Thread Starter
Doug
I hope someone can help me. I bought a 67 that came off the strip and the interior is completely stripped. I need some ideas on what to do for the floor system, steel or aluminum? I really have no idea what I'm doing in regards to this step and have never done any sheet metal work so any help you guys can give would be fantastic.
The rest of the cars interior will be aluminum and this is going to be a pro street car when completed.
Thanks guys,
Doug
critteral is offline
post #2 of 18 (permalink) Old May 27th, 10, 10:36 AM
Mickey
Moonpie's Avatar
Re: what to use for floor?
Is the floor missing? How much is there? Toe boards gonne be replaced? Firewall? Aluminum is noisy as hell on the street.
Now, no offense. But what are you personally trying to do? Just make a decision? Do the work yourself?
Moonpie is offline
post #3 of 18 (permalink) Old May 27th, 10, 10:46 AM Thread Starter
Doug
nothing there but frame, and cross frame from narrowed rear end joining front sub no fire wall or toe boards. motor mount have been set back about 3". so i take it that you suggest a steel floor?
post #4 of 18 (permalink) Old May 27th, 10, 02:06 PM
Christropher
Pictures are worth a thousand words. Got any?
Christropher
...in pieces still.
clwilcox33 is offline
post #5 of 18 (permalink) Old May 27th, 10, 02:52 PM Thread Starter
Doug
you are correct on the pictures. I will post a couple in the am when i get back to the shop. Thanks Christropher
post #6 of 18 (permalink) Old May 27th, 10, 05:04 PM
prostreet69camaro's Avatar
I agree aluminum is noisy and rocks will dent the aluminum tubs. Are you gonna put carpet over the floors?
prostreet69camaro is offline
post #7 of 18 (permalink) Old May 27th, 10, 05:39 PM
Royce
For a street car, go with steel hands down.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #8 of 18 (permalink) Old May 27th, 10, 05:53 PM
Andrew
Andrew69's Avatar
Seems it would be less expensive and faster to just install a complete new floor pan.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 18 (permalink) Old May 27th, 10, 06:56 PM
Christopher
psy4s's Avatar
X2 on the floor pans. You can get it in one piece now for a very reasonable price, then make adjustment as needed.
Time is money.
psy4s is offline
post #10 of 18 (permalink) Old May 28th, 10, 06:32 AM Thread Starter
Doug
double post
post #11 of 18 (permalink) Old May 28th, 10, 06:40 AM Thread Starter
Doug
Ok guys, dont flame me, this is how i received the car
I was thinking the same with a stock floor pan as well. second question... what do you think in regards to the firewall? put back in a stock cowl and firewall and then just cut the firewall for the motor being set back or put the motor back in stock position with a stock uncut firewall?
thanks for the help, like I said earlier, I have zero experience with metal work, my background is that I'm a 45 year old, that has done nothing but engine and electrical work on cars, so this is new territory for me and I am truly thankful for any help and direction that you guys can give me.
[ATTACH]Click image for larger version
post #12 of 18 (permalink) Old May 28th, 10, 06:56 AM
Kevin
Unfortunately the way it is right now you will have to go a long ways back to put a full floor in properly and turn it around. Good news is everything is available and reasonably priced plus you'll get to learn a few new skills along the way if you tackle it yourself.A replacement floor pan will not go over the extra metal they have there and will not work very well with the current rear suspension. I would still think it would be the best approach for a street car over aluminum not to mention you probably will want the head room back over the current setup.
My 68's resurrection thread
Shandara is offline
post #13 of 18 (permalink) Old May 28th, 10, 08:40 AM
Mickey
Moonpie's Avatar
To install a full floor it would have to be cut up and fitted around everything. It can be done. Other option is to remove all the bracing in the way, install floor and reinstall bracing. I see now why you asked about aluminum. For street use I think I would cut up the full steel floor and install.
If you had the coin taking it to someone who builds race cars would be another option. They do that sort of thing all the time.
Moonpie is offline
post #14 of 18 (permalink) Old May 28th, 10, 08:52 AM
Rico
use a sheet metal floor kit like this one http://autoweldchassis.com/frames.ivnu
or
http://www.rjays.com/Direct_Sheetmet...t-metal-01.htm
XLexusTech is offline
post #15 of 18 (permalink) Old May 28th, 10, 09:04 AM
Here is some options for doing your own floors and fire wall. You will have to see if they come in steel or aluminum.
Aluminum you will have to pop rivet in.
Steel can be spot welded in.
Then caulk all seams.
https://www.secureway1.com/alston/in...?categoryID=98
http://www.cachassisworks.com/c-256-...eet-metal.aspx
Make your own templetes out of cardboard or poster board. Cut your own metal and build your own sheetmetal brake.
http://www.stevehenryracing.com/brakeplans.htm
