rear end - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 26th, 10, 02:49 PM Thread Starter
Jon
rear end
67 sbc 500 hp , tko 600 5 spd. What should I run out back for a weekend 1/4 mile run and street driving. 4/10 or 4/56 on a 28" od tire with 12-13" section width and 10'' rim?
Caltracks with 12 bolt?
Four link with 9"?
I'm open here guys for options.
JR67RS is offline
post #2 of 6 (permalink) Old Oct 26th, 10, 03:10 PM
Terry
Re: rear end
JR, You didn't say which overdrive ratio for 5th gear you have. There are two 5th gear ratios .64 and .82 for the TKO600.
If you have the .82 the 4.10 rear gears would be my preference for street and strip.
If you have the .64 it would be a coin toss for me because in either case 1st gear has a ratio of 2.87.
I installed the TKO600 in my '56 Chevy DelRay with 3.70 posi and 27.5" tall tires. I went with the short throw Keisler. It made banging the gears alot of fun.
IRON MAN is offline
post #3 of 6 (permalink) Old Oct 26th, 10, 03:12 PM Thread Starter
Jon
Re: rear end
Sorry. its the .64
JR67RS is offline
post #4 of 6 (permalink) Old Oct 26th, 10, 07:51 PM
Frank
Re: rear end
At 500HP and 3400LBS? Your car should run 115MPH. Assuming your car turns 6400RPM I am guessing for a 500HP SBC? With a 4.56 gear and 28" tall tire she will run 116MPH in 4th gear.
It will also run 70MPH at 2500RPM in 5th gear which ain't bad.
For suspension, if drag racing is most important, Cal tracs and split monos are great but handle terrible. If you want both handling and drag ability you need to look at a Chris Alston G Link which has ajustment for both handlling and drag setting and in between.
We do quite a few G Links if you want to explore this more.
ProdigyCustoms is offline
post #5 of 6 (permalink) Old Nov 4th, 10, 03:43 PM
.gearhead.'s Avatar
Re: rear end
4.10
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #6 of 6 (permalink) Old Nov 4th, 10, 03:56 PM Thread Starter
Jon
Re: rear end
4.10 it is
JR67RS is offline
