Where should my timing be set at? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 18th, 11, 01:08 AM Thread Starter
Joe
Just got the car running about a month ago. Trying to figure out where my motor is comfortable at. Its a 67 camaro, 468ci, 13:1 compression, 725 lift comp mechanical roller, 1050 dominator, Brodix heads/intake, weights 3200lbs. Car is only set at 32 degrees total right now. Feels great pulls hard to 7200+rpm but I know it has more in it. I was planning on setting the timing at 38 degress @ 3000rpm but I thought I'd ask first. Does anyone have a similare build or any suggestions?? Thanks for the help
joes468 is offline
post #2 of 4 (permalink) Old Aug 18th, 11, 03:35 AM
Re: Where should my timing be set at?
As long as detonation isn't a problem, go ahead and try it. Take it to the strip and try it at 32, 34, 36, and 38 and see how she acts. From your combination, I'll bet you end up at 38 degrees.
buenymayor is online now
post #3 of 4 (permalink) Old Aug 18th, 11, 04:14 AM
Camarodude67
Wow sounds like a heck of a motor and assumsion is that you are running grape juice (VP) for fuel?
Jeff G.
camarodude67 is offline
post #4 of 4 (permalink) Old Aug 18th, 11, 12:44 PM Thread Starter
Joe
Yup she runs on 110 octane.. I'm guessing I will end up around 38 too . Just thought I'd ask to be on the safe side. Havent been able to make it to the track yet due to work but Ill let you guys know what happens. Thank you for your help....
joes468 is offline
