Big brakes behind 15x4 rims - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 29th, 11, 05:38 AM Thread Starter
67 455 Bird ragtop's Avatar
I was looking at the front rims on my car now that I finally got tires one them. It looks like there is room there possibly for some bigger brakes. The off set is 1.75" and looks like there is room for bigger rotors and brakes. As long as the off set of the rotor is the same. Anyone running bigger brakes with their 15x4 skinny rims/tires ???
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 8 (permalink) Old Aug 30th, 11, 09:12 PM
Royce
Re: Big brakes behind 15x4 rims
Not sure what you are calling "bigger". Really not going to be a huge help cause the tire will be your limiting factor on stopping power. Meaning that the skinny tires aren't going to hold the stopping power of huge brakes, and will be more prone to lock up.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 8 (permalink) Old Sep 1st, 11, 07:09 AM Thread Starter
By bigger I meant something like a C5/C6 setup. But your point in the skinny tire patch is well taken. Thanks for bringing that up. Guess I'll stick with my stock single piston calipers or maybe some of Wilwood's direct replacement models.
post #4 of 8 (permalink) Old Sep 2nd, 11, 06:31 PM
prostreet69camaro's Avatar
I am running the Baer front disc with the skinny tire on front.
prostreet69camaro is offline
post #5 of 8 (permalink) Old Sep 3rd, 11, 01:01 PM
Royce
I run Wilwoods on the front. I'm not saying you can't use decent breaks it just doesn't make sense to have 6 piston calipers and over sized rotors with skinnies. At some point the brakes are too much for the tire to hold.
When the OP said "over sized", by todays standard that can be pretty large and a lot of braking power.
post #6 of 8 (permalink) Old Sep 3rd, 11, 06:15 PM
Mine are the 4 piston calipers like your wilwood brakes. They are the direct replacements for a 15" wheel.
' wheel.
post #7 of 8 (permalink) Old Sep 5th, 11, 12:47 PM
I have 15"x5" front wheels with M/T 7.50 wide tires,SSBC non power 2 piston calipers and have decent stopping capability. I still have to change the distribution block from drum/drum to disc/drum....which I will do when replacing the old front brake lines with new ones that I recently purchased....just haven't found the time to do it!!!!!!!
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #8 of 8 (permalink) Old Mar 6th, 13, 05:07 AM
sIcKyIcKyMiCkY
A couple companys have c ome out with skinny tires for 17 +up rims.. mainly to clear big brakes..
1968 Camaro PRO STREET 406 Brodix .645 Roller Glide brak Dana 60 5.38 Ladr bar 32.16.5
1989 Vette Z-51 357 Dart ,Billet Specialties
1986 IROCZ- 468 400
2003 Roadstar
2003 GMC 4X4
Vette468 is offline
