Master Cylinder/Brakes for ProStreet Car - Team Camaro Tech
post #1 of 20 (permalink) Old Jun 1st, 12, 10:23 AM Thread Starter
Ben
Have been running Wilwood manual MC and dual piston calipers up front and 4 piston calipers in the rear. Running a manual adjustable prop. valve. 15x4 rims up front and 15x15 in the rear.
I am just not too happy with its stopping. What setup are you guys running and are you happy with it? Had been thinking of going power steering assisted MC or spending the bucks on an electric MC.
bensrat is offline
post #2 of 20 (permalink) Old Jun 1st, 12, 10:44 AM
cad
Re: Master Cylinder/Brakes for ProStreet Car
I'm running the Strange small bore m/c with Baer disc/rear drum, and it stops decent.
Do you have the master cylinder pushrod in the upper hole on the brake pedal arm?
What size bore MC is it?
1968 Camaro
cad is offline
post #3 of 20 (permalink) Old Jun 1st, 12, 10:59 AM Thread Starter
Ben
I believe the MC is 7/8" if memory is correct. Was installed few years ago. Not sure which hole its in, never looked..will ck when i get home today. Is the upper preferred?
bensrat is offline
post #4 of 20 (permalink) Old Jun 4th, 12, 09:15 AM
Bruce
I'm also running the small bore (1.031) Strange M/C, part number B3360, with a single piston disc brake setup up front and a Strange rear drum setup and I have no issues.
I also have the pushrod in the top hole.
If you only have .875" bore, that might be your whole problem, you should think about going to a 1.125" bore.
69 Camaro, 496, 10.34 @ 134.77 mph.
bruce69camaro is offline
post #5 of 20 (permalink) Old Jun 4th, 12, 02:38 PM Thread Starter
Ben
usually the larger bores are for power assisted so i am told by wildwood. thanks for reminding me about the pushrod as i forgot to look.
bensrat is offline
post #6 of 20 (permalink) Old Jun 4th, 12, 04:51 PM
Dave C
I have 4 piston wilwood on all four corners with 7/8" bore manual its an ok stop wouldn't want to have to stop to quickly but they are ok.I was told by wilwood the 7/8" was what was needed for manual.Do not use dot 5 fluid.
PRO.ST69orange
post #7 of 20 (permalink) Old Jun 4th, 12, 10:24 PM
Hydraulic assist (hydroboost) works great, but I wonder how much extra stopping power you'd actually get with skinny front tires. If you can lock up your wheels now anything beyond that wouldn't help.
BPOS is offline
post #8 of 20 (permalink) Old Jun 5th, 12, 03:17 AM
Bruce
Actually, Strange recommends P/N B3360 (1.031) for a 4 piston rear/ 2 piston front brake setup. The larger Strange unit, P/N B3359 (1.125) is recommended for a 4 piston front and rear setup.
The B3360 was recommended to me by S&W Racecars when it came time for me to buy my setup.
Here is something that I found which is interesting. In this article this guy wrote:
"Smaller diameter master cylinders can be used to increase output pressure. The design allows the application of two master cylinders being applied at the same, thereby doubling the volume output. Because of this high pressure output, you will not need a vacuum booster."
So in theroy your setup should work fine.
I can tell you the first time I drove my car after I did the brake system, the brakes were "squishy" and then my wife helped me bleed the brakes again and there was a small amount of air still in the lines and now it works great.
Just so you know, here are my components: M/C Strange B3360, adjustable prop valve, 3/16" steel line up to the calipers/ drums, #3 braided line going into the calipers/ drums. I'm using DOT5 fluid and as I mentioned the pushrod is on the top hole on the brake pedal. Wheels are 15 x 14, and 15 x 3.5.
Good luck.
post #9 of 20 (permalink) Old Jun 5th, 12, 06:03 AM Thread Starter
Ben
Mine dont lock no matter how i adjust the proportioning valve. I stll havent looked at the hole on the pedal. Been working on replacing my braided fuel lines with Teflon inner braided lines. Cant stand the fumes in the garage anymore. Hope to be done tonight with that so will look at the pedal.
bensrat is offline
post #10 of 20 (permalink) Old Jun 5th, 12, 06:12 AM
Bruce
Hey your over on YB as well?
post #11 of 20 (permalink) Old Jun 5th, 12, 06:25 AM Thread Starter
Ben
yeah!!
bensrat is offline
post #12 of 20 (permalink) Old Jun 5th, 12, 06:30 AM
Bruce
Were you involved with the posting the other week about gas smell in the garage?
If not, it had a lot of good tips but the biggest one was capping your vent when your not using the car.
The one thing I found funny was, a guy suggested putting vanilla extract in a bottle and I think he mixed it with water and sprayed it in the air. They said the vanilla is a neutralizer and killed the smell.
post #13 of 20 (permalink) Old Jun 5th, 12, 06:36 AM Thread Starter
Ben
I tried the vent by putting a valve on it, but still didnt solve the problem, so then i tried running a hose to the outside from the vent and it didnt fix the problem either but helped a little. So, last night i took the 4 main braided lines off the car; tank to pump, pump to filter, filter to regulator, and regulator back to tank. Replacing them with braided with teflon inners. Hopefully that will do the trick. Plan to finish it up tonight. Pain in the a** doing this lying on your back.
Little gas smell wouldnt bother me, but it was really bad and with the summer heat and humidity here in Florida its just too much.
bensrat is offline
post #14 of 20 (permalink) Old Jun 5th, 12, 06:47 AM
Bruce
I hear you about the heat. It was bad last summer here in PA as well.
I had the same problem and I had to air out my house for days. Here I found out that raw fuel was lying inside my mufflers, so I took them off and sat them outside and the smell went away.
I kept mufflers on it to help keep peace with my neighbors, but since my neighbors can be somewhat of a pain, I decided to just run it with open headers.
Good luck with the new hose.
post #15 of 20 (permalink) Old Jun 5th, 12, 06:50 AM Thread Starter
Ben
thanks
bensrat is offline
