Battery hold down for drag race - Team Camaro Tech
post #1 of 18 (permalink) Old Aug 11th, 12, 07:50 PM Thread Starter
Chuck
Sorry if I am in the wrong forum with this.
I am in the process of getting the car ready for the strip, and I need a battery hold down. The battery is in the stock location. I have been told to use a flat steel bar with 3/8 inch threaded rod, but I am looking for something that will look better.
Will something like this be legal?
I am not sure if the bolts need to be 3/8 inch or if the rods on this will meet the requirement. I have looked at JEGS, and they seem to offer stuff similar to this one (like billet specialties). Any advice would be appreciated!!
Chuck617 is offline
post #2 of 18 (permalink) Old Aug 11th, 12, 07:56 PM
Michael Gekko
Re: Battery hold down for drag race
Contact the tech official at your local track and see what he/she says. looks good to me.
Eleanor's Nemesis is offline
post #3 of 18 (permalink) Old Aug 11th, 12, 08:52 PM
Kev
"I am looking for something that will look better."
What race are you trying to win?
67sc is offline
post #4 of 18 (permalink) Old Aug 11th, 12, 10:04 PM
Royce
Race cars don't have to be ugly.
Is your battery reloacted? If it's in the stock position, you don't need anything fancy. If it is relocated take a look at the NHRA rule book.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #5 of 18 (permalink) Old Aug 11th, 12, 10:31 PM Thread Starter
Chuck
Just really trying to have some fun and a nice car, I don't really think I will win anything. I have been a competitive motorcycle racer for years and just looking to have some fun.
Great suggestion on contacting the track, I will do that, thanks all.
Chuck617 is offline
post #6 of 18 (permalink) Old Aug 12th, 12, 02:38 AM
If in stock location...I think that'll be fine. But as always, check with your local track.
68 Camaro~LSx ~all motor
post #7 of 18 (permalink) Old Aug 12th, 12, 07:39 AM
You can "pretty up" a piece of flat bar and make it look decent. I did mine by welding a couple of chunks of angle iron to it so it wraps around the batt a bit better. Not a show stopper but clean and effective. This is a trunk mount but you get the idea.
BPOS is offline
post #8 of 18 (permalink) Old Aug 12th, 12, 10:46 AM
Royce
This is how I mounted mine, trunk mount.
[IMG][/IMG]
[IMG][/IMG]
post #9 of 18 (permalink) Old Aug 12th, 12, 11:05 AM
Royce
Here are the rules for batteries, directly from the NHRA rule book:
"All batteries must be securely mounted. Batteries may not be relocated into the driver or passenger compartments. Rear firewall of .024-inch steel or .032-inch aluminum (including package tray) required when battery is relocated in the trunk. In lieu of rear firewall, battery may be located in a sealed .024-inch steel, .032-inch aluminum, or NHRA-accepted poly box. If sealed box is used in lieu of rear firewall, box may not be used to secure battery and must be vented outside of body. Relocated battery(s) must be fastened to frame or frame structure with minimum of two 3/8-inch bolts. ("J" hooks prohibited or must have open end welded shut). Betal battery hold-down straps mandatory. Strapping tape prohibited. A maximum of two automobile batteries, or 150 pounds combined maximum weight (unless otherwise specified in Class Requirements), is permitted. Maximums may vary according to Class Requirements."
Your local track has to follow these same rules if they are a sanctioned NHRA track and even IHRA follows the same rules.
post #10 of 18 (permalink) Old Aug 12th, 12, 11:10 AM
Royce
The first sentence (of the rules) is why I asked if you were keeping it in the stock location, if so it just has to be securely mounted, meaning not loose. The stock hold down is fine so the one you have pictured would be more than enough. If putting it in the trunk then things get a little more complex.
post #11 of 18 (permalink) Old Aug 12th, 12, 01:51 PM
As said, each track is different in interpeting the rules.
My track had said the OE clamp-on bracket was not good enough - needed a over-top-holddown bracket. A bracket to hold the battery in place in case vehicle rolls over.
So, 3/8 inch allthread, a hole drilled in the rad support and a 3/8 inch bolt/nut and a commerical top bracket passed inspection.
Then later in life, moved to the trunk, made a bracket like Al's (BPOS) and used 3./8 allthread through the frame rail with fender washers underneath the rail and cutoff switch.
post #12 of 18 (permalink) Old Aug 12th, 12, 08:36 PM Thread Starter
Chuck
Thanks so much for all the replies, I read the rules several times and it seemed to me like OEM hold down would be allowed, otherwise 3/8 rod is required. I emaild my local track at Doug's suggestion they got right back to me and said that hold down would not pass, 3/8 rod or bolts are required.
Thanks to Al and Royce for the pictures. I am going to make something like BPOS and have it powder coated so I will have no question. Thanks again for the replies and help. I hope to get this car going and get my first 1/4 mile in before the summer is over.
Chuck617 is offline
post #13 of 18 (permalink) Old Aug 13th, 12, 02:36 AM
To be honest... I've only had my stock battery checked a few times and all they did was grab and shake...no looking.
Mine is now in trunk and simular to this but in mild steel.....
post #14 of 18 (permalink) Old Aug 13th, 12, 04:54 PM
Royce
There are plenty of bone stock cars fresh off the showroom floor that race all the time with nothing, but what came from the factory.
Old cars had poor battery hold downs "not secure". I agree different tech inspectors have their own "rules".
That's the main reason I asked if it was going to be trunk mounted, they get a LOT more picky when you move it to the trunk.
post #15 of 18 (permalink) Old Aug 13th, 12, 05:42 PM
I tried to get this version to fit in the stock location in my '69....the base was too big and interfered with the inner fender.
I sold it to a friend of mine and he installed it in the trunk of his '67 Camaro alcohol injected drag racecar.
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
