Rear qtr panel wheel well lip - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 13th, 12, 07:14 PM Thread Starter
Ben
When tubbed, did they cut the wheel well inner lip? If removed are u happy with the eveness of the cut job?
Can u post a pic?
bensrat is offline
post #2 of 9 (permalink) Old Aug 14th, 12, 04:56 PM
prostreet69camaro's Avatar
Re: Rear qtr panel wheel well lip
Which part are you actually talking about?
The part that attaches to the quarterpanels or the part that attaches to the frame.
prostreet69camaro is offline
post #3 of 9 (permalink) Old Aug 15th, 12, 06:07 AM Thread Starter
Ben
The lip that would hold the chrome wheel well molding.
bensrat is offline
post #4 of 9 (permalink) Old Aug 15th, 12, 08:09 AM
.gearhead.'s Avatar
I didnt have to trim mine on a nice fit. But I'm waiting to see how much the tire grows at speed. Once I see that, I'll decide whether to trim the inner lip or go with a shorter tire.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #5 of 9 (permalink) Old Aug 15th, 12, 11:56 AM Thread Starter
Ben
When I bought my car it was already tubbed and the lip was cut. They didn't do a great job of the cut so they put a chrome edge molding to hide imperfections. I am trying to decide if to take the car to a body shop to smooth out what's there and ditch the edge molding or spend big bucks to have quarters replaced and stretched to make it look original. If I don't plan to install wheel well moldings I am not sure I need the expense. I just want the front and back to be similar as either both having moldings or both none not what I have now with nothing in front and edge molding for the rear.
Thoughts?
bensrat is offline
post #6 of 9 (permalink) Old Aug 15th, 12, 02:43 PM
.gearhead.'s Avatar
I didn't cut mine out because 1) it hasn't been necessary, and 2) I want to stay true to the original look of the car including trim. So I started with original quarters and chose to keep them that way.
In your case, it seems you have a decision to make and it's based on how much you really want to have OEM appearing quarters. Only you can answer that. If it were me, it would depend on whether the car is purely a weekend beater or a show and go piece. My 2 cents...
Now: Boost...
post #7 of 9 (permalink) Old Aug 15th, 12, 04:03 PM
I stretched my quarters 5" for the 33" tires. I have the original lip on mine. The tubs are big and are caulked to the quarters.
post #8 of 9 (permalink) Old Aug 15th, 12, 05:13 PM Thread Starter
Ben
Think its easier to stretch on a 69 cause you already have the straight edge at the top as mine has a curvature all the way around the tire.
Think is what i will do is see if for under $200 a body shop will fix what i have now so i can take the edge trim off, and when i get the car painted down the road have them do the qtrs then so i am not paying for paint twice.
bensrat is offline
post #9 of 9 (permalink) Old Aug 16th, 12, 05:18 PM
Harwood makes a extended wheelwell opening in fiberglass. This is a option.
http://www.eharwood.com/catalog/cata...+WELL+OPENINGS
