Fuel line size - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 3rd, 13, 02:14 PM Thread Starter
JOHN
Fuel line size
I have a big block chev with a f1r procharger on it and it will make between 1000 to 1200hp.what size fuel line should i run and should i use hard line, stainless, aluminum or steel or braided line.
BIGBLOCKCHEV is offline
post #2 of 3 (permalink) Old Feb 3rd, 13, 02:42 PM
Re: Fuel line size
I would say 1/2". I used -12 push-loc ? to the pump/filter and 1/2" aluminum line to the regulator and then -8 braided to the carb.
Worked well on my buddies N/A 505 BBC @ 9.1X Nova Now spraying to mid 8's (separate system), so I copied as I'll always have room to grow.
68 Camaro~LSx ~all motor
post #3 of 3 (permalink) Old Feb 3rd, 13, 03:12 PM
.gearhead.'s Avatar
Re: Fuel line size
-12 from the tank to the pump, -10 from the pump to the regulator, -8 from the regulator to the carb, and an -8 or -10 return.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
