67/8 wheel well openings ? - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 7th, 13, 05:29 AM Thread Starter
67 455 Bird ragtop's Avatar
Question for you 67/8 owners running big, 31x18, tires. Did you mod the wheel openings or leave them stock?? What, if any, issues do you have removing your wheels ???
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 5 (permalink) Old Mar 23rd, 13, 01:42 AM
Greg
Re: 67/8 wheel well openings ???
Stretched 1.5 inches. I'll see if I can find before and after pictures for you. There was no issue removing the 31's before or after.
1968 Prostreet Camaro - 540ci Big M, Dart Heads, 200-4R, narrowed 9"
2002 Hayabusa - 1464cc Muzzy's Big Block, low and slow
SS14PSI is offline
post #3 of 5 (permalink) Old Mar 23rd, 13, 01:51 AM
Greg
Before:
After (same 31x18.50 tires in all pictures)
SS14PSI is offline
post #4 of 5 (permalink) Old Mar 27th, 13, 04:55 AM
Bruce
I know this is a little late and also a different year, but I kept the stock opening on my 69 and use 32 x 14 Goodyears on 15 x 14 rims w/ 4.5 offset and all I do is let the air out if they need to come off.
69 Camaro, 496, 10.34 @ 134.77 mph.
bruce69camaro is offline
post #5 of 5 (permalink) Old Jan 1st, 14, 01:18 PM
Lance
I'm in the process of installing Harwood stretched wheel well openings on my 67 Camaro. It has 31x16.5-15 ET Streets on it. The old quarters were stock with the front and rear of the openings stretched out in a sort of hillbilly fashion. It didn't look bad from a few feet, but up close they didn't look that good. So now I'm installing these, and think I might step to a 33x18.5-15 ET Street now, the car needs some gear taken away anyways (has 4.88s and runs out around 1000ft on spray) and I think 33s will fill the wheel well a little better.
Before:
Now:
1967 Camaro
598 BBC - TH400 - Prostreet
Competition is offline
