Fuel cell on street ??? - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 18th, 15, 05:27 AM Thread Starter
67 455 Bird ragtop's Avatar
Foam or no foam ?? Trying to finalize my fuel cell design. Will primarily be a cruiser with an in-tank fuel pump. Juggling whether or not to put foam in it.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 8 (permalink) Old Dec 18th, 15, 08:32 AM
MARK
Send a message via AIM to PROZ11
Re: Fuel cell on street ???
I'd go with foam. I have no foam in my current set up so my fuel gauge is all over the place when I drive due to the fuel sloshing around. I had a similar cell in my last car for 10 years with foam and didn't have this issue. Neither of mine had an in tank pump.
PROZ11 is offline
post #3 of 8 (permalink) Old Dec 18th, 15, 12:46 PM
No foam here....and have a few buddies tell me that the ethanol eats the foam over time clogging filters.
No issues without it yet....but now I do wish I had a sending unit in it
Sucks calling wife to bring the gas can to me. (10gal.cell)
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old Dec 18th, 15, 01:32 PM
Steve69SS396's Avatar
I've had the same 16 gallon cell with foam for the last 10 years.
Steve69SS396 is offline
post #5 of 8 (permalink) Old Dec 18th, 15, 03:02 PM Thread Starter
Ok. Foam it is
post #6 of 8 (permalink) Old Dec 18th, 15, 05:16 PM
Royce
I have always run foam in my cells. The current one has foam that is probably about 10 years old, no issues.
Another option is to use baffles, the next cell I build, I plan to use baffles.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 8 (permalink) Old Mar 31st, 16, 09:17 AM
Apprentice
Harv
I need to change the 5 gallon cell for something bigger and went with the 15 gallon fuel cell from Speed Daddy on ebay. They are excellent quality for the money. The foam will probably taken out as I`ve had trouble with it breaking down on straight methanol. Although our fuel may not have that much ethanol in it I'm not willing to take a chance. Anyway its all coming together getting the car turned back to a street car.
Homestead is offline
post #8 of 8 (permalink) Old Sep 8th, 16, 02:41 PM Thread Starter
Ok have an update for this thread.
I have a 15 gallon fuel cell I'm getting ready to install. It's made from .100 thick 5051 aluminum. It will be mounted between the frame rails. Should I build a steel box to go around this cell to protect it from road debris ?? What gauge steel should I use ?? Car will primarily be street driven.
