Tubs ??? - Team Camaro Tech
 2Likes
  • 1 Post By pittpens24
  • 1 Post By PROZ11
post #1 of 5 (permalink) Old Nov 16th, 16, 03:40 AM Thread Starter
67 455 Bird ragtop's Avatar
Tubs ???
Aluminum or steel ?? Which did you use and why ???
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 5 (permalink) Old Nov 16th, 16, 04:03 AM
Greg
pittpens24's Avatar
Re: Tubs ???
Steel - so they could be welded in to the outer wheel housing and inner trunk pan. I wanted everything as structurally sound as possible on my build. I would use aluminum if I wanted that race car look where everything was beaded and rolled aluminum with a full cage of course.
arocars likes this.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 5 (permalink) Old Nov 18th, 16, 08:35 AM
MARK
Send a message via AIM to PROZ11
Re: Tubs ???
I also used steel for the same reasons. Seems like a better choice for street use.
arocars likes this.
Pro Street Z11 clone
YOUTUBE VIDEO:
PROZ11 is offline
post #4 of 5 (permalink) Old Oct 17th, 17, 01:52 PM
Joe
Re: Tubs ???
Steel for me, too. Much more solid when putting the back pieces together with steel.
Remember you're unique...just like everyone else...
CO68Camaro is offline
post #5 of 5 (permalink) Old Oct 17th, 17, 04:30 PM
Re: Tubs ???
If you are doing a functional street car i dont think aluminum is a rational choice
3d cad is offline
