Biggest Tire - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 7th, 19, 05:24 AM Thread Starter
Bruce
Biggest Tire
What is the biggest tire you can run on a 69 without having to stretch the quarters?
Currently I'm preparing to install 33 x 18.5's MT Street ET tires but I'm having a hard time
thinking I'm going to cut apart, GM quarters that I installed and are straight as an arrow.
A friend wants me to look into a small, but wide tire, like the MT 29 x 18.5, so will this size
fit without cutting things open? I believe the opening is like 30"?
Anyone have any pictures of a Camaro with these on?
69 Camaro, 496, 10.34 @ 134.77 mph.
bruce69camaro is offline
post #2 of 2 (permalink) Old Oct 7th, 19, 01:19 PM
Steve69SS396's Avatar
Re: Biggest Tire
My car is mini tubbed with large tubs from Chris Alston so my limiting factor on diameter is the wheel opening. I'm running 29" X 12" slicks and 29" X 14.5 Hoosier QTP's. To get them to fit I did have to trim the front lip of the wheel opening by about 1/2".
ID:	229677   Click image for larger version
ID:	229679   Click image for larger version
Steve69SS396 is offline
