air compressor pressure - Team Camaro Tech
Tools & Shops Shop Rat HQ
 3Likes
  • 2 Post By allanjs
  • 1 Post By HawkX66
post #1 of 13 (permalink) Old May 1st, 19, 06:34 PM Thread Starter
Kevin
How long does your shop compressor maintain air pressure? My system is pretty old, not very complicated and I don't leave it plugged in. I've finely gone over it with dish soap and sealed the leaks I could find. It used to loose all the pressure in a couple of days, but now only looses a couple lbs. a day. It's a lot better, but now wondering if it's possible to get it to hold full pressure until I need it.
KRhat is offline
post #2 of 13 (permalink) Old May 1st, 19, 06:52 PM
Re: air compressor pressure
I set my compressor up with a ball valve ~4" out of the tank. It's a safety issue.
If a line blows, coupler gives up, etc. I can quickly kill the line pressure. My tank
and tank fittings don't leak. I just shut the valve off when not needed. Eliminates
any leak down due to hose, fittings, etc.
rogerh and HawkX66 like this.
my 67' build thread:
allanjs is offline
post #3 of 13 (permalink) Old May 2nd, 19, 04:21 AM
Ball valve on mine always gets shut off and it doesn't loose any air. I do it in case I forget to kill the breaker and a hose breaks etc.
bcr45 likes this.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #4 of 13 (permalink) Old May 2nd, 19, 09:16 AM
Darin
ilikeike's Avatar
If I don’t leave any tools or blow gun plugged in, I know my setup maintains pressure over long weekends when I haven’t used it. Seems like the cheap Home Depot blow guns always leak a little at the trigger.
But normally I always close the ball valve at the tank anway.
All my runs are copper pipe.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #5 of 13 (permalink) Old May 2nd, 19, 05:34 PM
Ive always drained mine down at the end of the day...compressor tanks rust from the inside out
jump to 1:45 if you like...
68 Camaro~LSx ~all motor
post #6 of 13 (permalink) Old May 3rd, 19, 07:22 AM
Paul
Check the connector and the end of the hose where you connect your tools. Mine was slow leaking from there, changed it and no more leaks
Paul
fsc66 is offline
post #7 of 13 (permalink) Old May 15th, 19, 06:28 PM
Mine had a check valve where the compressed air enters the tank. When that valve failed on mine the tank would start to decompress as soon as the compressor shut off. Maybe that valve is leaking slowly on yours?
68 400HO Conv.
68Conv400HO is offline
post #8 of 13 (permalink) Old May 15th, 19, 07:04 PM
Roger
rogerh's Avatar
Normally if that tank check valve fails the compressor wonít start or has a hard time starting. The purpose of the check valve is to keep the pressure off the compressor head so it will start easier. The pressure switch should have a bleed off valve, to bleed the pressure off the compressor head after the compressor stops. If the tank check valve fails the air leaking out of the pressure switch bleed off valve should be very notable.
Roger
rogerh is offline
post #9 of 13 (permalink) Old May 16th, 19, 06:28 PM
Roger
Agreed. When mine leaked it failed fully open so the air bled out fast. Looking at a new check valve, it doesn't appear very high tech. I was only thinking an old one might not seat perfectly due to a scratch, foreign matter, wear, etc. resulting in a minor leak. It was only an idea to look for a leak when one cannot be found elsewhere.
68 400HO Conv.
post #10 of 13 (permalink) Old May 17th, 19, 01:14 AM
Kev
Put a ball valve when the air leaves the tank. Wire a switch in the pressure switch circuit so you can shut things off.
Might want to work on an air system past the tank because what's in the pic isn't good enough to be a joke.
You can search the internet, and figure out the good and bad techniques. Picture where water goes when it cools...
67sc is offline
post #11 of 13 (permalink) Old May 17th, 19, 05:13 AM
keith
X-77 keith's Avatar
Ball valve like others said is important. I kill the power and bleed the water out every night. I then bleed the water out again in the morning. Then go down the line and bleed the water separation systems. My system is about I years old, and always has 150 psi in the tank. Quality fittings and quality valves are key in reliability and safety.
X-77 keith
X-77 keith is online now
post #12 of 13 (permalink) Old May 17th, 19, 05:59 AM
Vega$69's Avatar
Ball valve at the tank. Donít want to leave the hose pressurized an risk having it burst a snake all over causing damage
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #13 of 13 (permalink) Old May 17th, 19, 07:55 AM
As suggested, install a ball valve to turn off hoses, etc.
Also, clean air filter, and as suggested drain tank removing moisture from tank.
You may need to increase hose/coupling size in getting volume of air.
The smallest orifice in the distribution system determines the volume of air delivered at end of hose.
Also, right angle elbows tumble the flow as air moves through system. Use a radius curve.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
Cowl Air Cleaner for 68 Camaro with ZZ502 sschas Restoration Corner 0 Jan 23rd, 19 12:56 PM
Air Filter Rubbing Against Hood Insulation HAMBO Restoration Corner 10 Sep 23rd, 18 11:34 AM
Carburetor Question Brettallen59 Engine 21 May 16th, 18 11:19 AM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
AC Delete, Vintage Ait, Old Air, Classic Auto Air stope4Rev1 Heating & Cooling 3 Nov 25th, 17 05:51 PM
