Top of the line performance brake kit! - Team Camaro Tech
post #1 of 1 (permalink) Old Oct 15th, 15, 04:59 AM Thread Starter
Baer brake systems are created to exceed the demands of the most serious car enthusiasts. If you consider yourself one of them, Extreme Plus Brake System is for you. This top of the line performance brake kit includes 6-piston monoblock calipers for lightweight two-piece rotors, stainless steel caliper hardware, and pre-loaded ceramic brake pads. It is designed as an upgrade for the highest performing street vehicles and can provide optimum levels of strong, progressive braking during aggressive street and track driving. This system is available for the Chevy Camaro 2010-2015.
Let your Camaro achieve the perfect balance of performance and control with Baer Kit.
Here are the main benefits of this system:
- Drilled holes and Slots create an escape route for debris, dust, gases, and water
- Slots help to increase pad bite and improve air circulation
- Multi-piston calipers provide clamping force on both sides of the rotor at the same time and uniformly transfer braking force to the brake pads
- Aluminum caliper body allows for exceptional light weight (up to 40% of weight savings) and ensures superior corrosion resistance
- Caliper heat-resistant coating prevent cracking and fading.
Share with us your feedback about this brake system in the comments below.
Chevy Camaro
Call Toll Free: 800.505.3274 |
carid is offline
