Holley Sniper EFI kit for a classic Camaro at CARiD - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 13th, 16, 04:16 AM Thread Starter
We are glad to announce that long awaited Holley Sniper Self Tuning EFI kit has been finally released and you can already preorder it at CARiD!
Estimated ship date is 15.06.2016 - be the first one to get it!
This is a unique system that looks just like a carburetor but performs like a brand new Fuel Injection system, giving you benefits of a modern car. It is designed to deliver a perfect air/fuel mixture every time you step on the pedal, which optimizes the fuel efficiency and results in increased power.
Easy cold starts will be highly appreciated by the enthusiasts from the northern states and Canada.
The ECU will tune automatically basing on the readings from the sensors and brief easy to understand setups right on the screen on this unit.
FEATURES:
- Direct bolt-on (designed to fit single & dual carb manifolds)
- Throttle body mounted ECU – no extra boxes to mount
- Supports up to 600hp (4 injector version) and 1200hp (8 injector version)
- 4 wire vehicle connection (Battery +, Battery - , Switched Ignition & RPM)
- Integrated fuel pressure regulator
- Integrated ignition timing control & coil driver
- Color touchscreen for setup and gauge views
- Calibration Wizard (Answer a few questions about your engine and it creates the base map, then starts tuning on its own!) - NO laptop required!
- Available in base & master kits (Master kits include complete fuel system: fuel pump, filters, feed and return hose and all fittings including fuel tank return line bulkhead fitting.)
- The included Wideband Oxygen Sensor provides realtime Fuel Map Learn!
Holley® - Sniper EFI Self-Tuning Kit
If any questions appear - feel free to contact me directly I will be glad to help!
Chevy Camaro
Call Toll Free: 800.505.3274 |
carid is offline
post #2 of 4 (permalink) Old Jun 13th, 16, 07:55 AM
Gary
69Z28-RS's Avatar
Re: Holley Sniper EFI kit for a classic Camaro at CARiD
Is this system designed so that 'stock' Camaro air cleaners, even drop base, will clear the system? and seal against the top of the unit? is the 'height' of the sniper the same as, for example, the holley used on high rise Z28 intakes? I'm curious what other modifications will be precipitated by swapping out my carburetor for the Sniper system?
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #3 of 4 (permalink) Old Jun 14th, 16, 12:40 AM
Lyle
X2
akwolf is offline
post #4 of 4 (permalink) Old Jun 22nd, 16, 07:52 AM Thread Starter
Doublechecking this your question with our rep at Holley! Will post the response within next few days!
Chevy Camaro
carid is offline
