Enhance Camaro's braking with Power Stop Z23 Brake Kit + CARiD Video - Team Camaro Tech
post #1 of 1 (permalink) Old Dec 17th, 18, 06:16 AM Thread Starter
Hey everyone! Today we'd like to talk about braking. Good brakes are just as important as a powerful engine. In case you're not satisfied with your factory brake system or your brakes are simply worn out, we have a solution for you - 1-Click Z23 Evolution Sport Drilled and Slotted Brake Kit by Power Stop. This bolt-on upgrade is one of the easiest and most effective ways to take braking performance of your Camaro to the new level. It will reduce brake dust and eliminate noise to make sure, that you can drive in comfort. We've dedicated our new video review to this brake kit and it's already available on our YouTube channel.
Power Stop 1-Click Z23 Evolution Sport Drilled and Slotted Brake Kit at CARiD
Features:
- Precision machined using a Tru-Castô technology
- Rotor run out is within 0.0015 and DTV tolerance specification is within 0.005
- All Evolution rotors are mill balanced
- Rounded slots keep a clear contact patch between the pad and the rotor by sweeping away water, gas and dust
- Beveled and precision drill holes help keep rotors temperatures down during extreme braking performance
- All drilled and slotted rotors (except for hub and rotor assemblies) are silver zinc plated to helps shield and resist rust during normal operation
- Pads, rotors and clips are designed in the precise size and shape of factory OEM parts for proper fit and operation - Carbon Fiber infused Evolution ceramic formula for superior braking power
- Brake pads and rotors offer eliminate squealing under the most extreme cold or hot temperatures
- 3-year/36,000 mile manufacturer limited warranty on the rotors and pads purchased and installed together.
Visit this page for all Power Stop Performance Brake Kits, Pads, Rotors, Calipers at CARiD.com
Improve the braking performance of your Camaro with Power Stop Z23 Evolution Sport Brake Kit. If any questions appear, reach me directly in PM or leave a comment below.
Chevy Camaro
Call Toll Free: 800.505.3274 |
carid is offline
