I have a 2002 SS Camaro that idles really rough. It kind of surges when it idles.When I put in gear It wants to die. I recently charged the battery and when it was on the charger and running it seemed to idle a lot better. Anybody have a Idea?
Thanks Mark
Thanks Mark
It idle better while you had it on the charger, then check the alternator and make sure its not running off the battery.
Sorry To take so long to get back. The Idle Learn Procedure worked. Saved by Team camaro again.
Thanks Mark
The idle relearn is pretty dramatic on those LS engines (probably more of an OBDII thing). I changed the battery in mine last year and thought something was seriously wrong with it the first time I started it. But after going through the relearn it runs like a champ.
