i have a 1987 camaro gutted for race only going to see weekend driving. battery relocated, 4" harwood cowl, weld pro stars, [email protected] pro stick , lakewood 90/10 struts lakewood 50/50 shocks summit racing seats,
355ci
dart 215cc platinum heads with 64cc chambers 2.05 / 1.60 valves
victor jr intake
holley 650 dp
isky solid cam with 507/507 lift 247/247 @ .50 lsa 108
headman long tube 1 5/8
1.5 roller rockers
flat top pistons 4 valve relifes
eagle crank
turbo 400 with 3500 stall [email protected] shift kit
3.73 gears
hoosier quick time pros 27/11.5/15
any guesses on times or h/p thanks
your 355 should make around 450hp, which should put you in the 11s easy, especially if your car is light.
i have a 68 nova weighed 2980, had a 355, ported old school vic jr's , xs282s cam, 11.5-1, 3.55 gears on 10.5 et streets, vic jr intake, 1.6 rockers, 1 7/8 supercomps, and a 780 holley...best i could do was an 11.8 @ 112mph with some tire spin...im guessing youd probably be pretty close to that
....after reading about 67rs502's luv im starting to think i had some thing seriously wrong...if i was still running that motor i bet i wouldve been doing at least low 11's with your input...let me know what you think when i get my big block finished...
