a 10 bolt posi rear in a 1970 camaro I am looking at has a 2.73 ? gear posi traction ,but when turning a corner you can hear and feel one tire jumping or chattering like there is no slipage at all .
how bad could this be ? Iam looking at a complete rebuild or a minor fix,the guy says he thinks it needs some posi lube
the car has a 454 motor/400 trans thats basiclly stock.
thanks
stock? 67
hidden 69
Jack up one wheel, place trans in nuetral, apply beam torque wrench, turn wrench, should be no less than 35 ft/lbs to slip clutches.
Probably would drain fluid, clean out old fluid with a couple qts of kerosene, drain, add new lube, AND GM's diff additive. Do figure 8's in empty parking lot for several minutes, chattering should be gone. Otherwise, a clutch pak change is required, if gears are okay.
