1 - 2 of 2 Posts
Hey Everyone,
I am picking up the 12 bolt rear end this weekend. I need to get the gears replaced and a posi unit installed but how do I figure out the parts for this? I see Eaton kits with everything in it that I considered but does anyone have any info on this?
Thanks,
Bill
You will need an Eaton posi, a ring & pinion set and an installation kit. That will be everything you need to set it up with a posi and gears for about $690. If the axles are bad then you will need a set of axles, axle bearings & seals and axle studs for about $210.
1 - 2 of 2 Posts
