Will 15 x 8 rally wheels with 265 50 15's fit on my 68? Will they rub? My other option is to put 15 x 7's on the front and 15 x 8's on the back.
Thank you
Rick
68 RS Convertible
427/TH350/12 bolt 3.73 posi
14 x 6 rally rims !!!!!!!!!!!!
Hi rick...I had 15x8 rallys on my 67 with p2756015 I had problems with them rubbing on the OUTSIDE when I checked the backspacing I found them to have 4" of bs (Vette rims, Camaro 15x8 ralleys have 4.5" of bs. So if you have 4.5" they wont rub.
I had 265/50/15 on a 15x8 Centerline with 4.5 inch backspacing and it rubbed on the inside when I turned into my driveway. Otherwise, I never had a problem.
and if they rub a little bit take a baseball batt with the wheel on and roll the inner wheelwell .... only if its a minor rubbing,, be careful not to crease the well..
