im wondering if you can fit a 15x10 inch wheel on a 69 camaro without modifying the rear end or quarter panels
Re: 15x10 wheel fitment ???
I used a 4.5" back space and a tire no taller than 28". I would remove the rubber bumper that bolts to the frame above the axle. If you run a taller tire, you may run into clearance problems at the front edge.
Re: 15x10 will fitment ???
I used 15x10, 28x10 slick. just trim the inside quarter panel lip..
how much backspacing 4.5 or 5.5 ?
5.5 on these Summit 10" chineese wheels, 15" of course. These tires are 28" tall. Believe me, they're tight. You don't want to run these on the street or anyplace you have to turn corners.
You can see the wheel lip trim in this shot. I did that back in 1969.
