The '67 & the '68 inner fenderwells are basically the same('68 rs has holes for headlight bellcrank). What is the difference(s) with the '69 fenderwell (how to identify). Thanks
69's have verticle ribs or indentations on the portion that is visible from the engine bay. I think there are 4 ribs. these face inward towards the engine. The 69 RS will also have have the large hole for the bell crank. I just tossed a pair of beat RS ones in the scrap bin.
Good luck!
Ted
I am not sure how the 69's compare to the 67's or 68's as far are size/dims, but I know the shape of the fender opening is different. I do not believe 69's and 67/68's are interchangeable. Maybe someone who is better versed with the difference between the two can chime in.
Good luck!
Ted
67-68 will not work on a 69. The portion of the wheel house that is flat in front of the tire is shaped different where it meets the fender. I think the 69 is straighter than the others.
Jeff
