Started another big part of the project today, I am off for the holidays and cant drive the car due to the snow. Today I started the install of my Detroit Speed subframe connectors. While performing this install I will be painting the floor and installing sound deadener. This project if gonna take me a while as I have never done this but hopefully I will have it done by the time I go back to work.
I decided to work on the driver side first. As you can see I have already primed the back seat area and put sound deadener across the drive shaft hump.
I was a little worried when I peeled back the rear carpet as there was a lot of surface rust. This area ended up cleaning up pretty well.
This is what the driver side foot well looked like before I cleaned and painted it.
With all the sound deadener removed the floor did not look to bad. I did not get a picture after I cleaned the floor but it looks pretty good after a couple coats of POR 15.
I kept the painting minimal today as it was all of 7 degrees outside so it was not exactly warm in the garage. That and I still need to do a lot of welding for the subframe connectors. I guess I am only allowed to attach 10 pictures per post. I will get onto the subframe connector install in the next post.
