Do you need a picture of the connector?
Usually the wiring is the same color, both ends of the connector.
Are you in the az camaro club?
Dale
I don't have the wiring colors for a 1967-68 turn signal switch but here are the colors for the 1969 and up wires. They just might be the same. Even if the color isn't the same, possibly the order might be.
White 18 gage - supplies the +12 v when the brake pedal is pushed
Dark Green 18 gage - Right Rear Brake Lights
Yellow 18 gage - Left Rear Brake Lights
Purple 18 gage - This is the +12v source for turn signal power
Brown 18 gage - Provides the +12v for hazard flasher operation (1968 only?)
Dark Blue 18 gage - Right Front
Light Blue 18 gage - Left Front
Black 18 gage - Horn ground when horn button is pressed
JIML82
