Looking for one 1967 door glass anti-rattle bar. Looks like this:
View attachment 303936 View attachment 303937
The ‘69 corvette style would be the one to modify.Could you get a 68 anti-rattle to work?
I saw at a couple smaller vendors stating the 68 - 69 unit was 67 - 69 Camaro & Firebird applicable. The 69 - 96 Corvette was different with a swedged stud in the bracket.
1968 - 1969 Camaro Door Window Glass Guide, Front, 7698543 (camarocentral.com)
That would be fantastic. Let me know.I'll have to check - I might have a few of these.
NPD has itLooking for one 1967 door glass anti-rattle bar. Looks like this:
Link? Because I don’t see it.NPD has it
Yay, let me know what you come up with.I might have one, let me look
I saw it in there catalogue. The fitting with the felt attached like OEM, in the window glass section.Yay, let me know what you come up with.
That‘s for ‘68-‘69. Thanks for taking the time to look.Sorry this is the only one I have. View attachment 304072
All they have is the ‘68-‘69 style like everyone else. Thanks for looking.I saw it in there catalogue. The fitting with the felt attached like OEM, in the window glass section.
The ‘67’s are a one year only. Thanks for checking.I’ve got a set of ‘68’s if that helps you. Fuzzies are tired
If you have the brackets, all you need is the fuzzy. Have any old window ones? Call PUI and see if they can help you out. How about a local upholstery supply store.The ‘67’s are a one year only. Thanks for checking.
I have only the one in post number one. Being a one year only these are apparently like finding hens teeth. I’ll just buy one for a corvette and make it work. Thanks.If you have the brackets, all you need is the fuzzy. Have any old window ones? Call PUI and see if they can help you out. How about a local upholstery supply store.
