Year:1967
Make:Chevrolet
Model:Camaro
Mileage:N/A
Transmission:N/A
Engine:N/A
Trim:RS
Clean title in hand, in my name
I have a build thread on this forum.
Only selling to finance my flying bug.
The car is ready to be blocked and painted the color of your choice. Do not get trapped in a car that will need a lot of extra work and parts. Parts are in short supply and the costs are just going up. Not to mention finding someone reasonable, good and timely to do the work is even harder. All that is left is the fun part of the build!
It was an original RS, Granada gold, std black interior 327 4 speed
Vin is original. Also have the original trim tag from this car.
Motor and trans not included for 22,500k.
All metal work is done.
Full inner and outer rockers
Full floor
Full trunk w/ drop offs
Full AMD frame rails
Full inner and outer rear wheel wells
Full AMD quarters
Full roof skin
Full firewall
Full cowl
Door skins, AMD
Full tail panel, an inner panel
All sand blasted and coated in southern polyurethane epoxy primer
Bottom and subframe is painted in trim black
SPC upper and lower control arms
Hotchkiss front and rear shocks
1.5 drop Hotchkiss rear springs
3 drop front springs
American Autowire full harness
90 rebuilt iroc qtr steering box
All new front end, sway bar and such
Rebuilt ls1 Camaro front and ls1 corvette rear brake setup
New brakes and rotors
New brake lines
8.5 rear end, open(for now)
New wheels and tires, 0 miles
I have a 4+ fenders, 2 hoods and 2 trunk lids.
Seats that need to be recovered.
Column that needs rebuilding.
Original pedal setup
Lots of original chrome.
All original glass, except front window.
Lows of small parts, heater box, glove box, ash tray and such.
For 5k I will include the motor and trans below I was building for this car.
rebuilt standard gen 3 LQ4
forged k1 rods
forged wiseco flat pistons
Original std polished crank
New king bearings
Titan 4 cam motion cam
Johnson lifters
799 fresh polished heads, cam motion dual springs
ls6 intake
dirty dingo mounts
Fresh rebuilt t56, no miles
GTO sequencers, but Camaro shifter setup.
BMR Crossmember
Used good clutch, pressure plate, flywheel
