I have a 1967 big block Camaro and it has manual drum brakes all four corners and stock suspension including single leaf rear, it has a 12 posi rearend..I want to upgrade to a multileaf and install four wheel power disk brakes. What is a nice set up that someone has done this...not looking for top of the line I would like to be around $3500 if possible.
Thank you
Th
Look at Right Stuff for brake conversion and any of the Camaro parts vendors on springs
I would go with Hotchkiss springs but others that cost less work fine. You will need a mono to multi adapter kit like the one from DSE
Reactions: gordr and fireboy
Reactions: fireboy
I dont know what you have for rims, but be careful with aftermarket brake kits. Many of them require larger diameter wheels.
Ricks is $475 after discount and $60 shipping.
Heartbeat City is $460.
I just bought and installed the show quality correct 4 Leafs on my Z28
