381 - 400 of 442 Posts
Discussion Starter · #381 ·
Thanks 350ss. I always thought that too, but I got my mufflers through Summit and they were $97 each. That was on par with all of the other mufflers I was looking at, so I thought it was a pretty fair price.
It took a little longer than I hoped to get an update, but I finally was able to get things complete enough to take it for a test drive last night. All I can say is WOW. When that boost comes on it just pulls so hard. Right now I think it does more of blowing the tires off, but I'm ok with that for now. I'd like to get a sticker set of 275 tires to see what happens when that power gets to the ground! I need to be careful because last night I punched it in 4th and when I got out of it I was over 100 mph! It went from 50 to 100 very quickly. I don't think I ever posted a picture of the new bypass valve. Brand new from GM.
After the test drive I doublechecked to see if my fix for the leaky shifter worked, and I'm happy to report no more leaks! I had to take apart the top shifter assembly and diagnose why it was leaking in the first place. I popped off the top cover and took apart the upper assembly that holds the fulcrum.
Here you can see that it was leaking all around that bottom plate and appears to come out on the right side.
Upon further inspection, it appears that there was some thread sealant that wasn't allowing that to sit flush against the lower plate.
So I cleaned that all off and dabbed a tiny amount of silicone around the fulcrum base when I reinstalled. I also added some thread tape to the four bolts that attach the upper and lower together. Just a little added insurance since they protrude into the trans case and are exposed to fluid.
While this was all happening I also needed to quiet down the car. While it sounded fantastic with the Flowmaster 50's, it would make my ears ring after every drive. So they had to go if I wanted anyone in my family to ride with me. After a bunch of sound clips, research and feedback from car buddies, I decided on a pair of Borla ProXS with a 14" case. They were significantly smaller than the 50's that came off of the car so I was actually able to tuck up my exhaust a little higher than before. I had to trim about 4" off of the pipes that come right before the mufflers to push them forward for a better approach to install the tail pipes. Minor modification, but necessary.
Next up was a pair of 3" Mandrel bent tail pipes from Flowmaster. While they didn't fit out of the box, I think that was completely my fault as I build my own exhaust from scratch. My mufflers are at an angle while the tail pipes are straight. So I just had to make a small cut to give the angle needed for my exhaust. My new band saw made quick work of that and gave a straight cut to just turn and weld.
The passenger side fit up really nicely and gave me plenty of room around the leaf and quarter panel. The driver side ended up being about 2" more rearward, so I ended up cutting it out of a straight section I had to match the passenger. Got it all welded up and re-installed. I still need to trim a little bit off of the end, but I'm very happy with the placement. I'm also debating on leaving it as is, or cutting it at an angle to match the quarter panel. For now I'm going to leave it straight and see how I feel about it.
Now for full transparency, the exhaust hangers are not finished, but I they are currently secured to the chassis. I am using the same rubber isolator mounts from before that are solid, but will need to be modified for the new location of the mufflers. The tail pipes may or may not be held up with mechanics wire, but I'll never tell... I have some proper hangers on order now, so once they come in I'll be able to get a final position for the tail pipes so I can get the tips just right.
Next up is to get my wiring cleaned up, the interior completely reinstalled and put some miles on her. Oh and maybe give it a bath haha.
Cheers,
Ryan
Discussion Starter · #383 ·
Not the greatest video, but they sound really good. Maybe it's just going to take some getting used to, but inside the car doesn't have the greatest sound. But when my dad sat in the car and revved it for me, damn did it sound amazing. Although it doesn't sound as good in the cabin as I was thinking, it's significantly quieter. I think that the tradeoff is well worth it.
Discussion Starter · #384 ·
It's been a few weeks since I posted. Finally took some time to clean up the wiring and tuck it nicely under the dash. I also installed the Custom Auto Sound radio that I picked up. It sounds great and I loaded it up with 1k songs and a flash drive for cruising. It sounds really good and looks way better than that double din unit I had under the dash last year.
I got all of my oil around to do my first oil change on the new motor. I've driven it around 200 miles on the break-in oil and decided it was time to get that oil out of there. At the suggestion of many of my friends who build motors, I wanted to cut the filter open to see what debris it collected. So I bought a used pipe cutter on eBay that would cut up to a 3" pipe. It was way cheaper than the dedicated filter cutters that I found. Not pretty, but I like the patina on it.
Unfortunately, I started having problems (I think coincidentally) after I installed my tailpipes. The car was running great, but then slowly started to develop a strange AFR spike. Almost like someone was turning a switch on and off. It would be cruising along at 14.7 right where I commanded it, then spike to 22+ and the car would nose over slightly. Give it throttle and it would clear up, but as soon as you drop down to a normal 5-10% TPS, it would start doing that again. I thought it was in my tune, but after logging it and checking things out, I think I have a hardware issue.
I pulled the plugs and understandably they were all indicating rich. Since it was dumping fuel to compensate for that lean condition. Plug 2 looks cleaner because I cleaned it off. All the others were as removed.
Now I think this may have been unrelated, but I found that Cylinder 7 had the strap pushed down and not sure if was even delivering spark. Would explain the fuel smell I have had especially at idle. But this was on the driver's side and my wideband is on the passenger side. So this wouldn't have explained the lean issue I was having.
At this point, I'm leaning towards a clogged/bad injector. I need to pull them out and inspect. I'm really hoping that is the case and not something deeper in the motor... Here is a screenshot of the log that I took where you can see it going crazy. The yellow line is where Closed Loop was turning on and off. As soon as it transitions the compensation spikes. The upper red line is AFR which is happy and where it should be, then something happens and the middle of the chart it spikes over 20 AFR.
Hopefully I can get this figured out soon. I'm missing out on some prime cruising weather. On a good note, I've officially fixed all the leaks on the car. I had a leaking pinion ever since I put the car together, but when I replaced the yoke, new seal and sealed the splines it hasn't leaked a drop. I also got the shifter leak fixed, and the few coolant leaks fixed. Hopefully I get this fueling issue fixed and I'll be back in business. I've got some brand new NKG plugs for when I get this straightened out. For now I'm just going to re-use these one's so I don't contaminate a fresh set.
Cheers,
Ryan
Discussion Starter · #385 ·
I'm back with an update and bearing good news. I found the source of my troubles! I had a bad spark plug wire where it contacts the spark plug. The terminal didn't "click" into place like it should normally and was loose fitting on the plug. It was a brand new spare MSD wire I had on the shelf and it was the last one I would have suspected. I test fit another spare I had and it clicked on tightly, so I swapped that one onto the car. I also installed the new spark plugs and it runs great, just like it did before. But the greatest thing is my fuel smell is almost completely gone now. I must have been running with that dead cylinder this whole time assuming it was my tune up. So word to the wise, check your plugs! The strange thing is I did check the header tubes and they were all hot enough to boil water when I sprayed them. I guess I need a thermal IR gun to confirm in the future.
Here is a comparison of the NGK BR7EF plugs to the Denso that I had in it. You can see how much taller the Denso is. I did use a borescope to check out the cylinders and pistons, especially Cylinder 8 where I had that damaged plug. I saw zero damage and nothing unusual. That was a huge relief.
In the meantime before I figured out it was the plug wire, I bought this neat little kit online that allows you to clean your injectors. It's a little adapter that goes on top of a carb/brake clean can and has a hole fit for an injector. It also came with a little harness with gator clips to activate the injector. I confirmed that I had a clean spray pattern on all the injectors, but I suppose it was good preventative maintenance if anything. It was super cheap on Amazon, $12.
I also forgot to share my father's day gift from the family. Some new Astrovents for my dash. The one's I have in there now are originals that look ok from a few feet away, but didn't work well and were pealing. These will make for a nice upgrade!
Now that the car is back on the road and firing on all 8 cylinders, it is an absolute blast to drive. It didn't seem to give a clean sweep from idle up and always had a little gas smell. With the new plugs (ordered some new plug wires too, but they are on the way) it was really easy to tuned up. Since I was having issues, I started with a fresh fuel table and a revised AFR table. It only took a few minutes of driving around for the fuel learning to kick in and it cleaned up really nicely. I thought I was happy with the tune before, but I'm way happier now. It runs really well now. Very responsive and idles perfectly. In my driving around I was able to clean up a slight bog off idle which was my only real issue I had before. On the way home I got a little brave and goosed it around a truck. Was going around 60 at the time, but to my surprise when I downshifted it broke the tires loose! This newfound power is definitely going to take some getting used to. Next on the list is a set of sticky tires!
I'm hoping to change the oil tonight and get it cleaned up for a car show in town. I've shared with a few people the issues that I was having with my Dad's 71 Chevelle and we finally figured that out with his car about a month ago. So this is the first time that we both have running/driving cars and can attend a show at the same time. Really stoked to park our cars next to one another. I'll post some pictures after the show.
Cheers,
Ryan
Discussion Starter · #386 ·
Great news is that my dad and I were able to make the car show and it was uneventful. No tow trucks, or any funny business. Both of our cars are running great and it was really cool having him there with me. My little guy helped me get the car all cleaned up so that was a fun time with him. I put some water in that spray bottle and he emptied it twice on the car and wheels.
I completely forgot to get some pictures, but one of my dad's friends was there and took pictures of all the cars. They sent them to us thankfully, but aren't full resolution.
My son loved checking out this firetruck that was there.
I already bought the upper radiator hose to replace the makeshift one that I bought to get the car up and running. When I was at the show, I had no less than 6 people mention that my upper hose was weeping. Well that was it, time to replace that hose.
Much better!
I also cleaned up the engine bay and snapped some pictures. Here's the engine bay all detailed and in it's final form. The only changes that I may make in the future may be some cooling modifications for the supercharger's heat exchanger. Some ducting to direct air across the heat exchanger, a possible rework of the mounts that will integrate in a dedicated cooling fan and adding a larger reservoir.
Cheers,
Ryan
Discussion Starter · #387 ·
Hi Jason, thanks for the compliments. Glad that my build was your first post after all these years! That's a compliment in itself.
Thanks for all of the input and feedback guys. I used almost all of those tips and believe that I've fixed the high IAT issues. I'll get into that shortly. I finally got around to doing my first oil change to change out the break-in oil and assess for any bad news. I'll be honest I was kinda dreading this and put it off. I was pleasantly surprised to find no major metal shavings or chunks in the oil. To be expected after all new bearings, there was a slight amount of glitter in the filter, but nothing in the oil that I drained out.
Then I swapped on a new matching set of plug wires to get rid of the mismatched set I had before.
I made some templates out of cardboard, and modified my HX brackets to tip the whole exchanger forward.
Once I was happy with the fitment, I welded the brackets back together. I also removed the J-nuts that I had before and drilled/tapped the brackets so it all fit a little tighter.
I was really happy with the cardboard templates, so I made some shrouds out of a spare piece of stainless plate I had.
Added some side filler plates and trimmed the upper piece up for a cleaner look.
Hard to get a picture of the "finished" product, but I wanted to test it out before I went and painted everything. That way if I had to modify it, I wasn't re-doing anything. Took the car out for a drive and unfortunately it didn't seem to help much at all. Slightly lower, but the temps still crept up to about 140* AND it was a cooler day than when I had the really high temps. Then I hot wired the pump like was suggested and watched everything. Well come to find out after about 3-5 minutes of running the water gets aerated! The water looks almost gray. So then I would kick the pump on and watch the water flow through the stock clear reservoir. What was happening inside is that the high volume circulation pump I have was draining the feed hose before the return could feed it more coolant. Once it all leveled out, the water became aerated. Air mixed with the water doesn't bode well for cooling. Thankfully I bought an Edelbrock reservoir a few weeks ago so I quickly hooked that up to see if this would help. Well it certainly did as ended up adding around 60oz of water even though that reservoir is only about 32oz. I kept working the hoses and shaking the HX and more and more air bubbles came out.
Went out and tested again with the newly installed reservoir and Bingo, that was the issue. Air in the system and a powerful circulation pump that was draining the lines. Oh and the JD bottle was for spill support not moral support haha.
After letting the car idle around this is what the temps ended up being. I bumped the on/off temps for my coolant too and that seemed to help with my radiator cooling too. It was about 78* when I took that picture.
Then I took the car to my favorite road, and let it spin through 3rd.
Going up my driveway I found this little guy running around. Had to chase him back into the fence haha. Sometimes I'm so glad that I have these guys as neighbors, rather than people haha.
My dad and I went to another car show on the 4th that was about 20 mins away. All the temps kept in check and it was a good time. I remembered to take some pictures this time!
To top off a great day at a car show and the car running tip top, I looked down on the way home at my MPG's. Cruising around it was clocking around 20-22 mpg. I took a picture and sent it to a few of my buddies where on coast, it was clocking over 30+ mpg's haha.
Can't wait to put some more miles on it. Next Sunday I have my second AutoX event, so I'm really looking forward to that. So glad that I got all of the bugs worked out.
Cheers,
Ryan
Discussion Starter · #388 ·
I wanted to do a "stress test" to see if my current setup could hold temperature or if I needed to upgrade to a larger/better fan. I got my wish by accident and was stuck in stand still traffic earlier this week. It was around 80* and cruising down the highway the ECT was around 190-192 with the IAT was around 95. That's where the engine temps normally ran the last two years with the LS1, so I was stoked because it was really efficiently cooling the new motor AND the IAT's are right where they should be around 20* over ambient. Well that changed when I was in stand still traffic for about 15-20 mins. I changed the fan temps to come on at 200 off at 205, so the engine temps went up to around 205 pretty quickly and the IAT just slowly gained a degree or two every minute. I had to pick up my wife from the service department for her car, and by the time I got there the engine temps were around 225 and the IAT's were 140. The temps just slowly creeped up which tells me that the fan just couldn't keep up.
I was hoping to get through the summer with this fan, but I don't want to hurt something by pinching pennies, so I picked up a low mileage take off C7 fan. Not sure if I'll try and use the stock shroud or make my own mount in my existing shroud. I want to get my hands on it and I'll make that decision later. It should be a huge difference. My cheapo eBay fan is rated around 2000 CFM, but I extremely doubt that is true. Maybe half of that. I found a company online called DeWitts who tested the stock C7 600 watt fan vs their upgraded 19" fan. The stock fan tested at 2900+ CFM at 90% duty. This should work really nicely for my needs.
Discussion Starter · #389 ·
I'm happy to report that the C7 fan install is now complete. I really liked how my current shroud covered the entire core so I wanted to find a way that I could mount the fan assembly to it. I started by removing the shroud and then test fitting the unmodified C7 fan.
The picture makes it look bigger than it is, but it has about 3/4" on both sides of the shroud when centered. Just way too deep and needs to be trimmed down. First picture is unmodified and mocked up. Could definitely be used as is, but I wanted it to fit tighter to the radiator.
Here's a close up of the motor. The 600 in there means that it's the 600 Watt version of the C7 fan. The earlier models could have come with a 500 Watt version.
I also debated on removing the fan from the shroud and making my own custom mount similar to what VA does with their aftermarket fan for 67-69 Camaro's. It fits nearly perfect in the 16" fan opening.
This is a VA shroud for my car that I saw at a Car show this past weekend. I think that is based of the Gen6 Camaros as it uses an even bigger 850 Watt fan!
Problem that I didn't want to deal with was how far away from the shroud it was going to sit. I could have fabricated something, but I didn't want to do that at this point.
One thing that was pretty interesting was that the inside of the fan shroud has these little ribs that are the same depth the entire way around the inside of the shroud. Stock there are 4 of those ribs, so after deciding that I as going to modify the C7 shroud, I cut 2 ribs off which was about 5/8".
With the 2 ribs cut, you can still use the stock mounting tabs, but since my radiator wasn't quite wide enough to easily use them, I decided to cut another two. Ended up being quite a bit of material that I removed.
I took measurements before and after cutting and the shroud must be parallel since the measurements were the same. Width is 21 3/8", side height is 13.5" and the height at the center is 15 3/8"
Discussion Starter · #390 ·
Here is right before one of the final test fits. I found that in between two of the ribs for the upper part, it lined up perfectly with the upper nuts that were already on the shroud. For the rear, I found a space between two ribs, but added my own Rivnut. Really easy and mounted very solidly.
Then I mounted up a 70 amp breaker for the fan. It draws a lot of juice and this was recommended to me by Andrew. I was able to use a little pillar and threaded a bolt I had into it for a solid mount. Very pleased with how it all came out. I had a few missing "flaps" and found a guy on a Corvette forum who had a few spares. So they are on the way, but for now I made a few temporary pieces. I'm not sure if I will end up trimming the shroud in front of the "flaps" to encourage more airflow at speed or not. I want to run it and see how it performs. If I am not getting the cooling I want I'll modify them for more airflow.
Installed in the car and ready to wire up. I'm really pleased with how it turned out.
I bought some more 8 ga wire, a 70 amp circuit breaker and a Yazaki connector kit (bought on eBay) with an assortment of terminals to get it all wired up.
I found that my big crimpers did a great job on the open barrel terminals once I bent them over slightly. One thing on this connector that was a little different was there is this inner white locking piece that had to be popped up in order to insert the terminals into the slots. Otherwise it was very straight forward.
Used some appropriately sized terminals and glued heat shrink. I didn't get any pictures, but the ground side goes directly to the battery. The positive side goes from the connector, to the breaker, then directly to the battery. From all my research it is critical to get the appropriately sized wire for this job. You will not be able to get away with 12 ga wire. According to Spal, this wire could get hot enough to melt the connector, so make sure the wire is sufficiently sized for the job.
The last thing was adjusting the tune in Holley to use a PWM- signal rather than a straight ground. I tested it in the garage and it worked great. I didn't get a chance to test it as it was raining, but I'm hoping to within the next few days.
Thanks,
Ryan
Discussion Starter · #394 ·
That's what I really love about the Holley software. It is very robust system that is very customizable. All of the Terminator X system's offer a PWM- control or ground as an output. Click on the I/O icon, then outputs and there is a drop down next to the outputs that you can select ground or PWM-. What's even next level though is with the Dominator ECU you can additionally output a PWM+, 12v or 5v outputs. Opens up way more options.
Discussion Starter · #396 ·
I'm pleased to report that the fans are working really well. I actually got stuck in stand still traffic over the weekend for about 15 mins and the temps stayed in right around 202-204. I have them commanded to come on at 202 and off at 198. The IAT's were good as well. They were around 90* cruising and crept up to around 108 and pretty much stayed there. The ambient temps were right around 70, so I'd like to do a stress test to find out what it does if the temps are 85-90 doing the same thing.
I'm still running the fan shroud as is and never cut open the inside. I think that I'm going to modify it to give the fan a more open space to draw the air from. I think that may encourage more airflow to possibly lower the IAT's. When I'm cruising down the highway I'm usually about 15-20* above ambient, so I know that it's cooling efficiently.
Discussion Starter · #397 ·
After cruising around I wasn't entirely happy with how the IAT's were reacting with the fans on. They weren't dropping like I was expecting, so after thinking on it a while I decided to make a change to the shroud. I found another guy who had the entire opening of the cooling fan he was running open (Thanks John), and the fan was riveted to the shroud. I really liked that idea and decided to copy that same concept. That meant I had to cut the shroud open and make some mounting tabs.
I'd guess that I gained an additional 30% more airflow through the C7 shroud rather than all of the air coming through the 16" opening that the shroud had before. Now there is a more direct path for the air to flow, but not only when the fans are on but at speed when the flaps are open.
I found a nice guy over on the Corvette forums that had a wrecked C7 and had 4 perfect flaps, which is exactly how many I needed. He gave them to me, all I had to do was pay shipping!
After a ton of test fits, I started to rivet them together. They turned out great and I'm very happy with the way it turned out now. Should have just done this from the beginning. Before when I was first cutting up the shroud, I saved the decal that came on the shroud originally. I wanted to put it back on when it was finished, and I'm glad I did. I think it was a nice finishing touch.
I also needed to shorten up my upper radiator hose. I didn't quite trim it enough when I first installed it, so now it doesn't touch the fan.
I'm finally happy with the way this turned out. It looks great and is actually more rigid now than it was before. The real test is if all the efforts were worth it. I finished this up on Friday night to hopefully make it to a car show on Saturday morning. Great news is that it was 80* out and I was able to get out to the show and test the fans out. The engine coolant didn't change at all, but the IAT's stayed lower. Huge win! I drove the car for about 100 miles and the whole car performed flawlessly, but especially the IAT's. I stopped to let the car idle for around 10 mins to see what it would do. The IAT's were right around 95* cruising then when I stopped they slowly crept up to around 125* and seemed to stay right around that temp. To me that seems pretty good considering all the engine bay heat and no airflow. I could probably get it a little better if I made a CAI shroud around my filter. I'll probably do that at some point, but for now I'm really pleased. The best part was the IAT's cooled right back down once I was moving again. Dropped 15* quickly then slowly went back down to around 95*.
Cheers,
Ryan
Discussion Starter · #398 ·
Not a ton of progress, but I swapped out my 255-45-18 tires for some Michelin ps2 275/35r18. I got them pretty cheap and they have helped slightly with traction. I got them for a really good deal to check for fitment, but I'd really like to go with a 275-40-18 eventually.
They didn't help that much though with traction haha.
I also picked up a set of 7.425" pushrods to see if more lifter pre-load will help to reduce the LS sewing machine sound. I know its very common with LS motors and aftermarket cams, but I want to try and reduce it if possible. Hopefully can swap those out over the next few weeks.
I also picked up this little tab for the ebrake switch. After I install that, I'll be able to hook up the light on my dash.
Cheers,
Ryan
Discussion Starter · #399 ·
I swapped out the pushrods Friday night and took some measurements. I used my adjustable pushrod checker and came up with the same measurement that I did when I built it originally. Zero lash comes out to 7.325". So with my 7.400 pushrods I come up with a 0.075" preload which is right about where the stock should be. BTR calls for a 0.100" preload, so I was right swapping out to the 7.425" pushrods. Glad to see that the inside still looks really clean. In addition to swapping out the pushrods I was tracking down a small oil leak. Good news is that the valve cover gasket had just pushed outside of the groove on the driver's side. Easy fix.
After that was all done, I took the car out on Saturday and it was slightly quieter, but not the results that I was hoping for. I'm guessing that it may not be the engine at this point, but maybe the design of the headers. I've heard various reports of different header manufactures where people have loud or quiet valves depending on that. I'm hoping to swap out my shorty headers at some point for some long tubes so maybe that will change things. I'm probably being particular because whenever I drive it I'm listening for it. Other people that have ridden in the car say it's not very noticeable.
Also Friday night, I got my parking brake wire hooked up and the new paddle installed. This was super easy and took me all of about 10 minutes. Nice to have a dash indicator now.
I'm hoping to get my new Astro Vents installed soon too. Just plugging away at the little things and enjoying driving the car.
Cheers,
Ryan
Discussion Starter · #400 ·
So I'll post up something that is a little interesting and a little embarrassing because I should have noticed it sooner. I'll start by showing my little quickie body work project. I've had some trouble ever since I built my car with some rubbing on the driver's side, which came to a head recently as I hit a road bump recently and my tire actually contacted the quarter. It wasn't serious damage thankfully, but it caused some paint damage when I hit it back in place. I'll fix this the right way this winter, but for now I had some Duplicolor color match rattle can paint that did a really nice temporary job. Just sanded it back a little with 400, then tapped it off, hit with primer and paint. Pretty pleased for a 20 min fix. Definitely not perfect, but it won't get any worse now.
When I was putting the wheel back on I started looking at that area and noticed that it seemed to be closer to the front than the rear. Then as I stepped back and got down I realized that the wheel wasn't centered in the wheel house. I didn't have tape measure right handy, but I checked and had two finger gap on the driver's side, and a loose 3 finger gap on the passenger at the front of the quarter. After I investigated further the rear axle had shifted forward at some point causing the wheel to not stay centered. I loosened up both the leaf spring pocket and the u bolts and made some adjustments and now it's the same on both sides. No idea how I didn't catch that sooner.
Before:
After:
Much better now!! I've driven it around and so far zero scrubbing.
I never drive the car at night, but I figured I should install the dome light. My son was interested in what I was doing when I was doing so I had him help me install it and cut the headliner. I also showed him how the circuits work. Probably forgot it already, but he was super interested at the time haha.
Best,
Ryan
