1 - 20 of 115 Posts
Had a thread under a different topic, so thought I'd share my reviews, issues, and photos here.
I previously had all stock: coils w/spacer, kyb shocks, and multi-leaf springs. The ride height was good/aligned. I also had 235/45/17 & 275/40/17 tires. After asking for help choosing a suspension kit, many advised that my rear tire setup would cause rubbing etc.. so I downsized the rears to 245/45/17.
Photo below (before)
https://flic.kr/p/2hQAaPx
I ended up getting the Ridetech StreetGrip suspension, and just had it installed. Overall, I can't explain how happy I am with the handling/comfort difference.
However...the only issue that's causing me pain is finding the best solution to align the ride height. Currently, the front is too lowered compared to the rear.
I've been asking around, and speaking to some of you. I've been told to go with lowering blocks and some suggested to just get 2" leaf springs from summit.
Note: The ridetech leafs are mono, and my perches are multi-leaf.
https://flic.kr/p/2hV8LkW
I'm about to order the Ridetech 1" lowering block for Multi-leaf, but looking at photos below..I doubt the 1" will help align the height much. This is what it looks like now.
https://flic.kr/p/2hV6neX
I spoke with Ridetech, since they have this photo below of the streetgrip with the height aligned, yes meatier rears but still perfectly aligned. They suggested to go with the 1" lowering block. The other reason is the quarter in my car is rounded vs this 69..
https://flic.kr/p/2hXTBWB
What options would you suggest on doing to get the ride aligned as close as possible.
Just hoping to get more additional feedback on here, and photos of similar setups.
Try the 1” lowering blocks. Do not change the leaf springs. You will destroy the ride quality given by the composite leaf spring.
If that doesn’t get you there a full tank of gas likely will. A slight forward rake will look fine.
Don
I think the 1” blocks will help you in the back. Is the vehicle realigned to the new Ridetech specs? Have you driven it much? If not the springs (especially the rear might settle. I would use this pic for your reference because there is a slight difference between 67-8 vs 69. Having trouble attaching a picture at the moment but look at the other pic in the add for the green 67/8 for new measurements.
https://www.ridetech.com/applications/musclecars/camaro/ridetech-1967-1969-camaro-streetgrip-system/
1" block will only lower 1/2" so I think you'd be good too. Love my street grip too. Wish mine was 1/2" taller in back. I'm hoping the front settles just a tad.
Really? Are you sure?
Pretty sure if you push the diff up one inch the car will drop one inch. At least that has been my experience.
Don
Reactions: yellow69RS
Don
Yeah, not planning to change them.
Sorry, what do you mean by realigned to ridetech spec? I wan't informed, just installed with no re-alignment. I've driven it for 2 days, not too much.
and yeah, the photos in the Ridetech website look different. Even the front of their cars is not as lowered as mine is.
Is that true, 1" will only lower 1/2"? .. if that's the case then I probably need to go with a 2" to drop the rear and have it as closely aligned as the fronts.
Discussion Starter #9
1" lowering block will lower it 1".
Are you front tire rubbing at all?
If so you can use some coil spring spacers to raise the front a litlle in addition to the 1" lowering blocks to get a better stance.
They come in different sizes from 1/2" to 1"
https://www.summitracing.com/parts/gls-1103/overview/year/1969/make/chevrolet/model/camaro
So looking at my rear gap visually, 2” might get it to where I want. I’ll measure it once im home.
Yes, fronts rub when going over a bump or unever surfaces.
I used to have spacers on my stock coils, wouldn’t the spacers affect the coil performance, harsher ride? Or it doesnt
Sent from my iPhone using Tapatalk
The old spacers you had twisted into the spring between the coils.
The one I posted from Summit go under to coils and do not affect ride quality.
I would lower the rear 1" with the blocks and raise the front 1/2" to 3/4" with the spring spacers. Will make it sit more even and will stop the tire rub.
Reactions: dhutton
The stance of this car has me seriously questioning Ridetech’s engineering and/or quality control. I had a similar issue with a Street Grip package for an A body car.
Surely they can do better or at least include the lowering blocks in their kit. Not sure what to make of the front being too low.
Don
Discussion Starter #12
Oh i see, yeah the old one i had looked scary lol. Ok then, I think i'll stick with the 1" block rear, and go with a 1/2" upfront
Thank you
Thank you
Be careful. A 1/2” spacer up front will raise the front of the car 1”.
Don
Discussion Starter #14
Don
I wish I knew they offered the lowering block kit. Completely missed it on their website.
Regarding the front, other than it sits way lower than rear. Too low: no gap, fender covering part of the top tire, plus the rubbing.
Discussion Starter #15
Don
I think i'll keep the fronts as is. The rubbing is only from bumpy roads, not while driving or taking a hard corner.. so I assume that's not tooo bad. i hope.
Don
They also sell a 3/8" spacer which will give you approx 3/4"
I also had the Ridetech ride height issue on the rear of my '66 Chevelle with StreetGrip.
After a couple frustrating calls with tech support I cut 1/2 coil off and it was perfect.
Discussion Starter #17
Just measured the rear fender to top of tire gap. About 2.4”
Cant even measure the front lol
The low front looks good to me, I'd want the back just as low with just a barely perceivable rake to the stance.
I had a 3" drop front and back on my 68 when I had the Hotchkis TVS setup, I liked it. I hope the lowering blocks get it where you want it.
Looks good but the tires rub
Discussion Starter #20
Given the 2.4” gap, i hope the 1” block does it
1 - 20 of 115 Posts
