1968 Camaro project journal for December (Fourth Week) 2022
12-24-22: It got up to near 20 degrees today. Yesterday evening and today, I’ve messed around inside with the new charging system parts. I painted the top of the relay satin black. The top of the voltage regulator was gloss black and had “Made in China” in white paint on one side. I painted the regulator top satin black to match everything under the hood. Can I help it if the county of origin got covered?
12-25-22: Merry Christmas!
12-26-22: No work done on the Camaro.
12-27-22: I removed the “old” voltage regulator (installed a couple months ago) and installed a new VR715 solid state unit as was suggested here on the forum. I used the rubber mounting feet that I had made to help cut down on vibration. However, this time I have a ground wire securely connected. I installed a new horn relay. I will finish up the wiring and fusible links tomorrow. The last thing I did was air up a tire (slow leak).
12-28-22: Got the voltage regulator and horn relay installed. There’s still a short in the wire that goes from the horn button to the relay. I replaced the old steering wheel with a new aftermarket one, so I probably have the horn wire connected wrong in the steering column or something like that. I’ll leave that wire disconnected from the relay for now. Reckon I don’t need a horn until it’s back on the road.
12-29-22: I have a new turn signal lever that needs installed. The old one is rusty and has a mounting angle too close to the steering wheel. The new lever is angled exactly the same as the old one. In the Summit photo it looked straight. I used a hammer and block of wood to take out most of the bend. I did a test fit and it’s now perfect. The horn wire in the steering column appeared to be connected correctly. However, I discovered one end of the ground wire on the rag joint was not connected. That’s my bad, since I’m the one who rebuilt the rag joint. I tightened the leaf spring front eye bolts. I still need to tighten the rear shackle bolts.
12-30-22: Got lucky and had a few days of decent weather. New Year’s Day is the last nice day before winter returns. I tightened the shackle bolts. Next, I installed a generic universal rubber trunk mat (one size fits most). The instructions said trimming might be needed. That’s quite an understatement.
12-31-22: I re-connected the ground strap on the rag joint. Unfortunately, there's still a short from the horn button to the horn relay. I might have to replace that wire entirely, but for now I’ll disconnected it. Lastly, I found a loose connection on the switched power wire that goes to the dash gauges. I re-crimped the spade terminal and plugged it back into the fuse block. The dash gauges started working again. Progress was made and I think the wiring harness was salvaged.
Summary of the 2022 Camaro project:
During the year 2022, I averaged about 120 to 150 hours of work done per month. I also averaged spending about $1,000 each month for parts. There were times when I started to feel a little burned out. But most of the time I stayed focused. A little daily progress over a period of time adds up to a lot of work done. I’m pleased with how things are going. The engine runs and looks fantastic. The Camaro was able to back up and pull forward under its own power. I was going to say I did everything myself, but I farmed out resurfacing the flywheel and tire mounting. Also, my wife lent a helping hand for things like installing the hood. I would’ve never got the windshield correctly in place without her help. The plan is to take a break during January, then continue working on the car this spring until its back on the road.
I took this photo today, New Year's Day 2023. It's been a long year, but I see light at the end of the tunnel.
