I have a stock 1968 Camaro and need a stock 15" rim for a spare tire. What Year 15" rims will fit my car?
Rick
Hi Rick,
Any GM rim with 4-3/4" bolt pattern will fit provided its a stock wheel. Unsure if you want a steel wheel or a rallye wheel. A standard rallye wheel has a 4.25 backspace which is what I run on my 68. Any aftermarket wheel/rim may not be the same backspace as the others you have. It should be noted that 15" wheels were only available from the factory on a 1968 Z28 however could be ordered from the dealer.
Kev
