I'm connecting a center console with guages wire harness to my under dash wire harness. The center console wire harness has a different connector then the under dash connector to console. The under dash has about 3 different wire bundles going to the console. I just want to clean it up some. Where can I get the under dash to console connector and pins to make one wire harness to the console?
While not OEM type connectors, I went to Ebay and found 2,4,6,and 8 pin connectors. I ended up using a pair of 4 pin connectors. In my case, my 67 has a center console and the reproduction gauge holder, but the three gauges in it are not the factory gauges, but rather an aftermarket oil, engine temp, and AMP gauge setup.
