Need to troublshoot purple wire to see why there is that 2.2 volt drop. Maybe bad connection.
From ignition switch, power passes through a connector for the saftey switch, then power goes through safety switch, then another connector after safety switch, then firewall connector and finally gets to starter solenoid.
You could run a new purple wire from ignition switch straight to the solenoid to see if 12 volts gets to the solenoid. If it does, then it is existing wiring.
