1 - 2 of 2 Posts
1969 350 4 bolt standard bore block with a HW stamping for a 350HP 4 speed application. The block casting number is 3956618 dated A-2-9 I believe without wire brushing it to verify the date. The block is stamped V0111HW so it went through the line on January 11th 1969. It has flat top pistons in it now and the cylinders are in excellent condition and the dome pistons could be put back in if wanted. I have the 3927186 heads rebuilt with screw in studs and guide plates dated A-27-9 & H-27-9 along with the correct 3927184 cast iron intake dated L-18-8. The engine comes with the pushrods, 5 blade clutch fan, fuel pump and chrome valve covers. Engine has a couple hundred miles on it after being rebuilt $3,000. Will sell without the #186 heads and I also have sets better dated for the engine but they are not ready to go at this moment. Any questions I can be reached at 330-770-2517 and can ship if you cannot pick up. Great engine for a pace car or other camaro.
Discussion Starter · #2 ·
Engine is sold. Heads, fan blade, valve covers, pushrods and head bolts still available.
1 - 2 of 2 Posts
