1 - 12 of 12 Posts
I have a 427 425hp engine all stock I am running a Comp Cam factory Muscle 520 lift 242 duration 107 intake center the most Idle vac I can get is 13 to 14 we played with timing no luck I had to add a vac pump to insure my power brakes does this sound normal?
Yes
I'm running a
• Adv. 288/300 .050" 229/241
• LIft 600/570 with 1.7
109 Lobe Sep
And I have great power brakes. Where are you drawing vacuum from? Mine is direct in to the intake behind the carb and not the baseplate of the carb.
I'm running a
109 Lobe Sep
Yours is a roller. Not sure what the OP has. Also 107 “could” make less.
Vacuum is developed when valves are closed. The narrower the LSA, the less time the valves are closed.
However, when decelerating, you have a closed throttle and vacuum should increase enough to the needed requirement for power brakes, i.e., 16-20 in/HG
You might check booster vacuum line/route is good and no kinks.
Also, you might run a vacuum gauge inside just to see how much vacuum there is in a driving condition.
Well, as far as the cam goes when you say "all stock", the cam can't be included, which is a critical part of how it will perform on the street. A 107 overlap is ridiculously too radical. Most of the 60's 427's were around 112-114. L88's were solid lifter. I'm not sure what the COPO's came with but my guesss was it fell in line with the L88's and L78's.
Discussion Starter · #10 ·
Thank You for your input When I say stock 11 to 1 compression not modified heads that profile is the closest to stock and listed as stock replacement I am considering a change I am not Drag Racing mostly street I am open to suggestions.
1 - 12 of 12 Posts
