1 - 8 of 8 Posts
I just bought a '69 Camaro sport coupe, that was from southern California, it is a 6-cylinder, but it is very solid, it has a/c in it, at first I thought it was a add on, because I thought 1975 was the first year of the a/c/ 6-cylinder availability. However, the compressor is GM, it has all the correct in-dash vents and controls, even the evap core casing looks factory, the engine code is BF which according to the Camaro White book is correct for a air-conditioned 250-6 cyl and manual trans. any body ever seen one that looks factory, or is it original? Chris
Does it have power steering? If so where is the compressor mounted? I have a 68 6 cyl that I added ps and wonder how hard it would be to add A/C.
I've got a 67 coupe that came from the factory with air and a 250 ci six, so I guess they have been around since day one.
I have seen a few 6-cyl A/C cars. It was an available option and is shown in the Assembly manual.
cs2000, could you email me or post the #'s of the car?
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 3/10/01)
A/C was available on any 67 thru 69 Camaro except those engines equipped with solid lifters, 302/290HP and 396/375HP.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Discussion Starter · #7 ·
the VIN is 123379N659863 The body plate is 69 12437 NOR 352981 711 67 67 06A X44, the engine # is F0601BF, the car has a 3-speed manual, it had a smog pump, no power steering or brakes. Chris
[This message has been edited by cs2000 (edited 04-30-2001).]
The Compressor is on the upward, passenger side.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
1 - 8 of 8 Posts
