Hey everyone... I'm trying to help a buddy out with his '69 SS-350 car.
This all started last fall. The battery died for some unknown reason. He replaced the battery, but it still kept going dead and having to be charged.
Thinking that it was some type of leak, he replaced the starter and the voltage regulator... but with no improvement. Then he changed the alternator to a new 61 amp conventional unit, but then ran into this problem.
The battery this spring was dead again. So... he pulled it, charged it , and had it load tested. Junk. So.. now he is running ANOTHER brand new 700 cca battery.
The voltage on the system is 12.65 when the car is off.
When the car is started... the voltage settles in at 14.6 V.
However, when he brings up the RPM at all... the voltage climbs to 15.5-15.7 Volts and sits there. We replaced the external voltage regulator, again, thinking that this could be the issue... but it didn't change a thing.
He is worried that he will be overcharging his battery. My understanding is that over 15 volts is too much. Suggestions?
We are at a loss.
We are at a loss.
