1 - 2 of 2 Posts
Looking at some rims and they had codes I had not seen before.
1969 (1970) KH 14 X 7 Rally Rim code MA.
Both rims had this code at the valve stem.
One was a K-1-0 12-8
On this above rim, there was M10 & 12-8 was left and right of the valve stem.
(I may have stated the day 8 incorrectly; it may have been 18)
The rim center was dated K-1-0 with no month letter.
The other rim had another date of which I now forget.
However both were stamped MA by the valve stem.
Even more strange this rim is that it had a K-1-9 on the rim center with a B month code.
Both were welded on the back side at the center's flange mating to the outer band.
Each rim had different weld patterns.
I am assuming that both could have been over the counter rims, but the welds suggested to me that someone may have made these up.
What do you guys think?
Those seem to be oddballs.. KH is Kelsey Hayes, the rim manufacturer K10 and 12 8 means they are Dec 1970 for the 1971 model year. MA isn't a typical ralley wheel code, so who knows what you got there.
1 - 2 of 2 Posts
