My front left signal is not flashing, but the fog light works, I replaced the flasher and nothing. It is also much slower then the right one. Can the cancelling cam go bad?
the cancelling cam has nothing to do with blinking, only cancelling.
The flasher is used in the same way for both sides, so it';s not the problem.
Most likely you have a bulb or 2 out somewhere, and the flasher is not getting loaded enough to flash. Could be a bad ground.
What car?
My guess is that you have a bulb out. Check all of them and replace the bad ones. Or it might be a bad connection or ground. That will take further checking with a test light etc.
TTFN
Mat
