I don't think my 69 has rear bump stops. At least I don't see them anywhere. Where exactly are these supposed to be located? I need to buy some and I could sure use info on part #'s.
Thanks!!
Not sure of the part numbers.... mine are pianted and were rusty so I can't get the numbers off them.
They are big 3" rubber bumpers, kind of pointed, mounted to the bottom of a 3" wide brackets that get bolted to the outside of the frame rails above each axle.
Here they are.... http://www.rickscamaros.com/product.asp?pf_id=SS-123&dept_id=3536
There's also one above the rear end, right in the center of the floor. Different part\part#.
