Is there a template that is available, or maybe a member that has correct measurements i can use to correctly cut-out a repro rear tail light panel for a 1969 camaro RS? I do not have the old RS panel for a guide.
thanks.
kdka.
I know the mail order catalogues sell them. But maybe someone in the site has a set for you. Since you would really only need them once. I'd give you the ones I used, but I borrowed the template from the guy who did my bodywork. He does restorations so he made up a set off of an original panel.
I had to replace the lower part of my tail panel with a repop after it was crushed by a bonehead who flatbedded my car when I got the rear subframe done. My car was not originally an RS.
Here's a shot of my tail panel after I cut them.
