Hi,
1969 RS Camaro here.
I have owned my car for about 4 years,the horn has never worked as long as i have had the car. I have done the following things.
1) Replaced the steering wheel /horn buttons and face of the wheel when i first got the car, because the wheel was cracked.
2) I replaced the horn relay because the horns did not work.
3) I figured out the horns were the originals and they were burned out,so i bought new horns.
Now that I have horns that work, when i open the drivers side door the horn honks.The horn also works when i use the horn button.
The car also is supposed to have a key buzzer alert when the door is opened and the key is in the ignition. I cant hear the buzzer over the horn.
I know the wires on the horn relay are not reversed because they only go on one way with plugs that are unique to each connector.
***Do I have some sort of grounding problem with the pink and black key buzzer wire ???
***Is the pink and black key buzzer wire somehow attached to the black horn wire by mistake at the wheel ???
If anyone else has had this problem , can you please post the solution.
