1 - 20 of 24 Posts
Hello all. Thought I would journal my restoration. First, thank you for all the support and guidance I have already received on this forum. Starting with a mostly complete 1969 350 SS, non matching engine and trany. Owned since 1999, drove till 2003 then parked. Car soild when purchased, had a fresh coat of black paint applied from MAACO. Good driver, parked due to family commitments (Kids).
Started restoration fall of 2022. Car was in running condition, paint ok, floor boards rusted. Decided full floor pan best option. This required removal of front subframe. This was a larger job then originally thought. Broke a few things during the process, overall went good. During disassembly noted firewall and one quarter panel needing replacement also. Suspect will find a few more body panels requiring replacement before done.
https://flic.kr/p/2omAudM
https://flic.kr/p/2omxS9c
Looks like you're too far into it to turn back now! These cars can be an addiction and a curse, but there is satisfaction in the journey once complete. Good luck!
Discussion Starter · #3 ·
Thank you for the encouragement. Spending a lot of time looking/dreaming at cars on line. Planning a resto-mod as wanting a few upgrades vs what I believe came from the factory.
Look forward to seeing your progress!
Nice. So you “broke a few things during the process”? Patience? Beverage Budget? Finger? Penalty for swearing?
Discussion Starter · #9 ·
I thought my steering column at the rag joint was free (blot removed). When I removed the the subframe body bolts, the subframe shifted forward damaging the rag joint. Also on of the body bolts was rusted and broke free the nut at the firewall. Bolt also broke. Not sure how I am going to fix this. At least it broke in a way the subframe was removeable.
U can arc weld nut at firewall once everything apart. if u can vice grip the stud(bolt now)
u can burn the bolt too,
The broken nut holder piece is available. Happened to me once, well nut was spinning. A buddy arc welded it down.
I agree with BEUNY and a few others above . Make sure all of your measurements are correct because a 32nd off here and there at the front end becomes an inch by the time you get to the back end.Alex
Discussion Starter · #13 ·
I agree with your remedy. As long as the bolt is still in the correct location, should be able to weld the nut back in place. Will be able to get some heat on the body bolt for removal. Only possible issue is if the mounting hole is too rusted and cannot get a good weld.
Discussion Starter · #14 ·
That is one thing that puts puts a bit of scare in me. Being off on my frame/body mounts. Want the car to drive straight when restored. Worse case the whole thing becomes some very cool yard art!
Technically the nut floats. There’s a cage welded over it which holds it. I bent my cage up. New square nut under it. Then welded old cage back down.
yep, it needs to float or you won't be able to align the frame when you put it back together, unless you weld it after you have the frame aligned and the bolt in place - but that might be difficult to reach then.
· Premium Member
In your disassembly description you mention the firewall needs replaced. if you are replacing the lower firewall/toeboard part it comes with new body mounts already on it.
Jeff
· Super Moderator
1967 RS Bench seat 327/2bbl/PG
Good luck with your project
Use anti-seize on the threads. A little dab will do you
You can square chassis to body using a plumb bob, tape to mark floor, and cross measure, ie, ball joint grease fitting to rear axle perch? LT front to Right rear & RT front to left rear
You’ll get there
Discussion Starter · #19 ·
The bolt broke during removal. When subframe was removed, that is when I noticed the nut was loose. Was unaware the nut floats, maybe I'm not as bad off as I thought. Will look into this further
Discussion Starter · #20 ·
Was planning on welding the nut to the firewall support, have to remove the broken bolt out of it. If its support to float, will have to come up with another option to fix the nut in place for bolt removal.
1 - 20 of 24 Posts
