car as stock alternator and regulator.
Car was not charging, so i purchased a new alternator ... after installing new alternator...still no charge.
Heres what i see; large red wire behind alternator as 12 Volts, little dark blue wire behind alternator as 12 volts, white wire as 0 volts.
I made sure that both white and dark blue wires have continuity between alternator and voltage regulator.
Voltage regulator harness as 12volts on all wires except for brown.
could it be the voltage regulator is no good.
How to check voltage regulator if it functions.
thanks
Tell us you didn't turn in the original alternator for a core, did you?
